Explorer, Sport Trac, Mountaineer & Aviator 1991-1994, 1995-2001, 2002-2005, 2006-2010 Ford Explorer
Wiring diagram for power window system
Old 01-23-2011, 08:05 PM
One Sock's Avatar
One Sock
One Sock is offline
I was playing with the power window wiring in a 94 Exploder, trying to disable the annoying one touch auto down feature. But the wiring diagram in the Haynes book doesn't match what I see in the vehicle--Haynes shows 6 wires on the one touch module, when in fact there are only 5, and the colors are all different. Anyone have an accurate diagram?
Old 01-24-2011, 12:52 PM
shorod's Avatar
shorod
shorod is offline
Interesting, most people wish more windows had the one touch feature. Does the '94 have the second detent for the one-touch, or does it default to one-touch and you have to press the button a second time to stop the window in process?
Which wiring diagram are you using so I don't waste my time checking EBSCO if you've already used that one?
-Rod
Old 01-24-2011, 12:53 PM
shorod's Avatar
shorod
shorod is offline
Sorry, I just noticed you typed "Haynes book." It must be Monday....
-Rod
Old 01-24-2011, 07:42 PM
One Sock's Avatar
One Sock
One Sock is offline
I can't stand any electronic system that tries to guess what I want and do it automatically; all too often it gets it wrong.
There's no second detent (that would seem like a much better system); I just push the down button and it goes all the way down unless I push the up button.
Old 01-24-2011, 08:37 PM
shorod's Avatar
shorod
shorod is offline
Does your one-touch module have wire colors red, red/yellow, light blue/black, yellow/red, and black? If so, it looks like you should unplug the one-touch module and jumper the red to the red/yellow wire. That should will take the one-touch module out of the circuit and should allow the window to function "normally".
The light blue/black wire is fused feed and the black wire is ground.
-Rod
Old 01-25-2011, 06:20 PM
One Sock's Avatar
One Sock
One Sock is offline
It works! Thanks for the help.
Old 01-25-2011, 09:45 PM
shorod's Avatar
shorod
shorod is offline
You're welcome, glad you got it the way you want it!
-Rod
rempie
06-07-2020 06:21 PM
juliomad
1997 - 2003 F150
05-22-2017 07:28 AM
Jterr
1999 to 2016 Super Duty
04-05-2017 06:34 PM
danorth
09-22-2016 01:24 AM
dldee
Bronco II
05-12-2016 02:41 PM
Quick Reply: Wiring diagram for power window system
