1999 to 2016 Super Duty 1999 to 2016 Ford F250, F350, F450 and F550 Super Duty with diesel V8 and gas V8 and V10 engines
2009 f350 v-10 block heater
Old 01-20-2011, 12:41 PM
Gizmo285's Avatar
Gizmo285
Gizmo285 is offline
These past few nights have been very cold. 10 degrees etc and I plugged my block heater in for apprx 2.5 hrs. I was expecting warm air in a few minutes from the htr and defrost after I started the engine but it seemed like it took almost as long to blow warm air as if I didn't even have a bock heater. What should be expected?? Thanks........Freezing in NY.....
Old 01-20-2011, 12:58 PM
J_E_Summit's Avatar
J_E_Summit
J_E_Summit is offline
Could you hear the block heater working? Also, did it crank over easier then it would have without the heater? I wouldn't expect to see a whole lot of difference at that temperature.
Old 01-20-2011, 02:08 PM
BIGBEAR6's Avatar
BIGBEAR6
BIGBEAR6 is offline
I plug mine in and leave it all night, in the morning after I start it I'll have warm air in a couple of minutes. 2.5 hours is not long enough Imo.
Old 01-20-2011, 03:48 PM
Gizmo285's Avatar
Gizmo285
Gizmo285 is offline
I just read in the book that it reaches max gtg after 3 hours ay 0 degrees... I'll put it on a little longer next time before i fire up the engine and see if the heat blows faster........
Old 01-20-2011, 05:03 PM
PhilbertMcFilibuster's Avatar
PhilbertMcFilibuster is offline
With a three to four minute idle, mine takes at least two miles of travel before it blows not cold air.
Old 01-20-2011, 05:38 PM
Gizmo285's Avatar
Gizmo285
Gizmo285 is offline
How long was it plugged in for prior to the driving?? And what temp was it out?? Thanks.
Old 01-20-2011, 05:46 PM
J_E_Summit's Avatar
J_E_Summit
My truck isn't the V10, but I can leave it plugged in all night and hardly notice the difference when it is that temp.
I don't usually use the block heater until it gets below zero and then it gets 3-4 hours on the timer. If it gets below -10, then I consider leaving it on all night.
If you want warm air, then you should try a 110V car heater. It is something I have been meening to do, but never gotten around to it.
Old 01-20-2011, 05:54 PM
Gizmo285's Avatar
Gizmo285
Gizmo285 is offline
I don't expect it to blow like a forced air furnace I was just wondering about some real world feedback. As long as the block is somewhat warmer i guess it is better for the engine. In a diesel it makes a greater difference than a gas on the effect of the startup so I guess I'll still leave it plugged in for the few cents of electric it costs. Maybe it will suprise me one day an blow 100 degree air at startup.... In the summer probably.........
Old 01-20-2011, 05:55 PM
CraigOutdoors's Avatar
CraigOutdoors
CraigOutdoors is offline
'Bout 19 or so this mornin. Started my truck and then cleared the snow off. By the time I cleared the snow off it, I didn't need to scrape any ice. Just had to brush it off cause it all melted loose already. By the time I got in the truck, I took off my jacket.
Old 01-20-2011, 05:59 PM
Gizmo285's Avatar
Gizmo285
Gizmo285 is offline
Thar was with the block heater plugged in I take it??
Old 01-20-2011, 06:04 PM
J_E_Summit's Avatar
J_E_Summit
19 is pretty warm, I wouldn't waste any money on the block heater at that temp.
Well, not with these motors.
I am not sure what the wattage is, but I would expect it to be in the 400+ range.
Old 01-20-2011, 08:46 PM
I only use it if it is below zero f (if I remember to plug it in before bedtime). It never occurred to me that a block heater was anything but a device to make the engine easier to start and cause less wear and tear on a frozen motor. No offence, but I think you may have a misperception of what the block heater's purpose is.
Old 01-20-2011, 09:31 PM
CraigOutdoors
Nope. She just warms up good. Its supposed to be down to 4 tonite. We'll see how she does tomorrow. I can't keep the heat all the way up for more than a 15 or 20 min drive or it turns into a sauna. I can only hope the A/C works as well in the summer.
bobcf
01-15-2015 06:40 PM
ithaca1230
01-23-2014 11:29 PM
BowDown
04-25-2006 06:28 PM
muckypaws
1978 - 1996 Big Bronco
12-04-2004 07:54 AM
mixer316
2004 - 2008 F150
03-08-2004 04:44 PM
Quick Reply: 2009 f350 v-10 block heater
