Pictures of processors
Old 01-16-2011, 02:08 PM
fabmandelux's Avatar
fabmandelux
fabmandelux is offline
Arrow Pictures of processors
I've had quite a few people ask for pics of processors so decided to add a sticky for it. If you have pics of your system post them here for others to look at!
I will sticky this thread but not lock it, so everybody can have access.
Let's see if we can help others to get started!
Old 01-24-2011, 08:01 PM
binuya's Avatar
binuya
binuya is offline
OK, I'll go first. Compared to some of the regulars here, my set up is probably the most primitive, but it works well for me. I water wash. My 55 gallon drum processor is also where I spray dry my bio after washing.
Here's the setup with heated standpipe wash tank to the left, processor in the middle, and pneumatic drill powered keg methoxide mixer to the right. Both wash tank and processor have 220v heating elements wired 110V thermostat controlled.
Here's the simple processor plumbing. This is fed into a cheap HF blue pump which has, surprisingly, held up well processing and drying just over 1500 gallons of bio. I am currently constructing a new processor which will have a Pedrollo pump. Better quality and much safer.
Old 02-06-2011, 10:10 PM
Rushmore X's Avatar
Rushmore X
Rushmore X is offline
Ok, now I'm going to have to update my pics.... Hopefully sometime this week. Gives me something else to do...
Old 03-07-2011, 11:46 PM
muns53's Avatar
muns53
muns53 is offline
I threw some pics of my conversion and my grease shack in my picture album. Nothing fancy, I'm filtering with a bowl-type centrifuge & burning WVO in a 2-tank system (modified Vegistroke V3) on my Excursion, not making bio.
Old 04-04-2011, 09:33 PM
flainn's Avatar
flainn
flainn is offline
Here's my processor, a pretty much bone stock Appleseed design made from a 40-gallon Home Depot water heater and currently installed on my 5'x8' trailer:
And here's my three WVO storage barrels and my wash tank:
Not pictured is my "super sucker", made out of a 50-gallon propane tank, which is also mounted on my trailer.
The processor and wash tank plans and parts kits were purchased from <a href="http://www.utahbiodieselsupply.com/">Utah Biodiesel Supply</a> (great folks!) and the Super Sucker plans were purchased from <a href="http://www.murphysmachines.com/">Murphy's Machines</a>.
Old 04-30-2011, 09:32 PM
frdf250's Avatar
frdf250
frdf250 is offline
Pictures of Setup
Heres some picture of my setup. Finally got the swing of things, thanks to you guys.
Old 01-17-2012, 03:38 PM
Rushmore X's Avatar
Rushmore X
Finally got around to it.
Old 02-19-2012, 10:40 AM
ATV PRO #11's Avatar
ATV PRO #11
ATV PRO #11 is offline
I have tons of pics of the plant throughout the build. Can't seem to figure out how to post on here. Don't think i'll get in trouble as the process was propritory not the set up/fabrication of the plant
Old 03-02-2012, 12:00 AM
ATV PRO #11
I'd like to see some pics of your set up
Old 03-02-2012, 12:03 AM
stemo76's Avatar
stemo76
stemo76 is offline
The easiest way is to post them to a place like photobucket and then you can add the link in the post or use the picture icon and add the url to the specific picture. Photobucket makes getting the links very easy.
Old 03-02-2012, 12:04 AM
ATV PRO #11
Old 03-02-2012, 12:05 AM
ATV PRO #11
Thanks!! I finally figured it out with some help. Appreciate it tho
Old 03-09-2015, 09:01 PM
TheCurtster's Avatar
TheCurtster
TheCurtster is offline
Here's my setup
This was during the processing of my first 20 gallon batch. Bought the processor, half drum of methanol, NaOH, filters, pumps barrels, etc. from a CL ad for $700. First batch was a success! Running about 30-40% ratio now. Getting up my nerve for a full 40 gallon batch next week.
Curt
Old 11-16-2017, 07:19 AM
IABill's Avatar
IABill
IABill is offline
Wink
Curt I have the same unit bought nearly 10 years ago. Sorry not smart enough to figure out how to post pics.Shut down now for winter but it has served me well.
Only brewing right at 600 gallons a year
Don't worry about 40 gallon batches its easy, I have never ran a 20 gallon batch
Old 11-18-2017, 11:27 AM
TheCurtster
That was my first attempt at cooking, and I’ve probably made about 10 40 gallon batches successfully since then. If there’s one thing I’ve learned, it’s to take time at each stage and let stuff settle out. It usually takes me about 2 weeks to make a batch.
Quick Reply: Pictures of processors
