2002 F150 4.6 Cylinder 8 Misfire
Old 01-12-2011, 10:15 PM
biebs53's Avatar
biebs53
biebs53 is offline
My buddy has an 02 f150 Screw 2wd and after a day of mudding he had a code that came up cyl 8 misfire. I assume its the coil but what else could it be? And what needs to v6 e removed to change cyl 8 coil? Looks like fuel rail is in the way.
Old 01-13-2011, 06:44 AM
torkum's Avatar
torkum
torkum is offline
Chances are that the spark plug hole got water in it and is causing the problem. You can take the coil out with out removing the fuel rail, just rotate it. Don't pull the plug until you are sure the hole is free of water.
johnno5
6.2L V8
08-29-2021 08:36 AM
Dillon Snyder
1997 - 2003 F150
03-09-2017 11:06 PM
zakarehamrick
Modular V10 (6.8l)
06-27-2012 06:01 PM
skoveng
Modular V10 (6.8l)
10-29-2008 07:07 PM
mitchymitch
1997 - 2003 F150
29
03-11-2004 07:15 PM
Quick Reply: 2002 F150 4.6 Cylinder 8 Misfire
