Is it a "Highboy" or a "Lowboy"?
Old 01-12-2011, 03:42 PM
Highboy74's Avatar
Highboy74
Highboy74 is offline
Here's the VIN: F26HRY80103. Any info will help. Thx.
Old 01-12-2011, 04:47 PM
NumberDummy's Avatar
NumberDummy
NumberDummy is offline
Ford Parts Specialist
Is it a "Highboy" or a "Lowboy?"
F26 = F250 4WD Pickup.
H = 351M
R = San Jose CA Assembly Plant.
Y80103 = 1977 (not a High Boy).
The last 1977 F250 4WD "High Boy" was assembled before serial number Y20,001 which occured mid-model year 1977 (February).
1977 F250 4WD's assembled from serial number Y20,001 thru the end of the 1977 model run (last serial number Z25,000), are not High Boys.
These serial numbers pertain to all Ford trucks (not just F100/350's), Bronco's & Econolines.
Old 01-12-2011, 06:05 PM
77&79F250's Avatar
77&79F250
77&79F250 is offline
Moderator & parts seller
Received 3,283 Likes on 2,439 Posts
Under front bumper frame cross member?
Divorced xfer case?
Rear springs are 2 1/2 wide?
='s Highboy, no to the above questions='s Lowboy
Old 02-16-2011, 12:04 AM
edwin76's Avatar
edwin76
edwin76 is offline
as long as (last serial numbers Z25,000) are not the last of my 76's vin, its a highboy? do the highboys originally have the raked look?
Old 02-16-2011, 03:10 AM
Sleepy445FE's Avatar
Sleepy445FE
Sleepy445FE is offline
all 76 f250 4x4s are what is called a highboy. Most likely your front leaves have sagged a little over the years. From looking at it though it doesnt really look like yours has a rake? maybe 1"?
Old 02-16-2011, 07:19 AM
77&79F250's Avatar
77&79F250
There is a thread dedicated to "Highboys" try a search, it has frame measurements and a ton of info.
And vins......
Old 02-16-2011, 09:39 AM
1977f250's Avatar
1977f250
1977f250 is offline
I see a lot of confusion about what is a highboy and non highboy. ANY Ford F250 4X4 truck from 73 to 77 and the 77 is before ser # Y20,001 Is what is nicked named a highboy. There is NO non highboy in these years. They are all standard Ford F250s 4x4s, the term Highboy is a nickname. There is nothing different about them, they all are the same as far as a highboy or non highboy. So if you have a stock 73,74,75,76 F250 4x4 it IS a highboy. 77 would be the only year that may or may not be a highboy. Highboys started in the mid 60s.
Old 02-16-2011, 10:16 AM
77&79F250's Avatar
77&79F250
I am not confused and I hope HB74 is not either, thanks for all the info I will ad it to my list.
Old 02-16-2011, 05:26 PM
edwin76's Avatar
edwin76
edwin76 is offline
Smile
cool thanks for clearing that up. lol i was confused. well i think your right that their worn. when i got the truck, it had blocks under the front leaf springs. thats why it looks straght. im looking to get a lift kit for it but for now the blocks are staying.
Old 02-16-2011, 10:20 PM
77&79F250's Avatar
77&79F250
An accident waiting to happen with those front blocks. IMO
Old 02-16-2011, 10:32 PM
Sleepy445FE
....X2....
Old 02-16-2011, 10:42 PM
cj06's Avatar
cj06
cj06 is offline
to make things simple all the trucks that are considered HIGH BOYS will have a Divorce mounted transfer case and 3 drive shafts , short one from tranny - transfer case then a rear and a front one !
the front springs will be positively arched on the high boys , when the change was mad in mid 77 the transfer case was bolted to the back of the tranny and only had a rear and front drive shaft and the springs were flattened out !
Old 02-16-2011, 11:05 PM
77&79F250's Avatar
77&79F250
Front block='s blockhead
Off thread subject, but those front blocks (pic 1) can cause pic 2&3.
The lateral forces your front end takes in corners is unbeliviable and those u-bolts are working hard even with the spring pack right on top the axle.
Putting a block in the front only multiplies those forces greatly, and can cause a catostrofic failure of them, meaning your friggin front axle could fall off.
And probably in a turn so you will be lucky if you do not roll your truck, kill yourself and anyone riding with you. Let alone anyone else around the accident.
I know it takes money and time for a lift, at least remove them till you can afford a proper lift kit.
The 2nd and 3rd pic are not from front block useage, but I wanted to scare you into taking them out. Drive safe and smart Ford brother!
Old 03-30-2011, 12:30 AM
edwin76's Avatar
edwin76
edwin76 is offline
well i kept the truck parked till now i replaced the blocks that came with the truck as of today. new leafs up front 2" lift and add a leaf on rear leafs. looks good and im happy the blocks are gone. one of em as already breaking. thanks for the warning. driving safe is the plan. =)
Old 03-30-2011, 01:49 AM
78 PEB's Avatar
78 PEB
78 PEB is offline
Good to hear you 86ed the blocks..............
Quick Reply: Is it a "Highboy" or a "Lowboy"?
