1985 F150 Not getting Fuel to Fuel Pump
I have a 1985 F150 that was running great. Now it will not start. I have done the following:
-New Fuel Filter
-New Mechanical Fuel Pump
It has a 2 barrel carb and two gas tanks.
I have NO fuel at the primary of the fuel pump. I tested with air pressure that should have forced fuel out of the fuel line and nothing.
Any advice is greatly appreciated.
-New Fuel Filter
on
Are you saying you pressurized the tank with air and got no fuel? I would think you would but if not make sure its not blowing air out of the fuel line, its possible the pickup tube has a hole or is broken inside the tank. Can you feel suction on the fuel pump inlet while cranking? I've seen the fuel pump eccentric bolt come loose.
19tanker
15
08-20-2020 04:10 AM
Motosk813
01-25-2016 08:08 PM
brookslion1
27
07-04-2011 06:30 AM
