1999 to 2016 Super Duty 1999 to 2016 Ford F250, F350, F450 and F550 Super Duty with diesel V8 and gas V8 and V10 engines
DPFE Sensor location on Ford F250 2006
Old 01-10-2011, 01:24 PM
Mike-11's Avatar
Mike-11
Mike-11 is offline
Hello Everyone,
Just wanted to know if anyone know where the DPFE Sensor (Delta Pressure Feedback Electronic Sensor) is located on a Ford F250 XLT 5.4L.
I look on the fire wall and driver side of the engine and I can't find anything. I believe I'm looking for a unit that has two hose coming out of it. Diagram or picture will be helpful.
Thanks,
Old 01-10-2011, 01:31 PM
redford's Avatar
redford
redford is online now
Received 1,565 Likes on 913 Posts
IIRC, a 3v 5.4L engine doesn't have a DPFE sensor.
Old 01-10-2011, 01:49 PM
Mike-11's Avatar
Mike-11
Mike-11 is offline
redford - Are you sure about that? I was searching around and the unit is flat with two tubes coming out of it. Some site tell me is located on the fire wall, enigine (driver side) or on the exhaust manafold. I believe I have to remove my Air filter unit and it will be under that. Again I'm not so sure.
I will call a ford dealer and see what they say. If I get any infomation I will post it.
Old 01-10-2011, 01:57 PM
Mike-11's Avatar
Mike-11
Mike-11 is offline
sorry I meant intake manifold not exhaust.
Old 01-10-2011, 02:21 PM
Mike-11's Avatar
Mike-11
Mike-11 is offline
redford- You are right, the 3V engines do not have a DPFE sensor. The Ford dealer could not bring up a part for that year and model.
I posted a P0174 code (System too lean - Bank 2). When I looked up the code it stated check MAF (Mass Air Flow) sensor. I clean the MAF but the truck still rides rough. It loses power once an while when driving. When you come to a complete stop the truck shakes like crazy.
I don't know if I need a new MAF, do you have any ideas.
Ford F250 XLT 5.4L 3V (8 cyl)
Old 01-11-2011, 08:34 AM
krewat's Avatar
krewat
krewat is offline
Site Administrator
Check for vacuum leaks.
Old 01-11-2011, 08:50 AM
redford's Avatar
redford
Also (may sound silly) but check your PCV valve also.
Old 01-11-2011, 11:26 PM
DernMooseAk's Avatar
DernMooseAk
DernMooseAk is offline
He really cant check the PCV, its under the valve cover. Really! Actualy I was told by ford it is part of the valve cover. Want to replace PCV, you have to replace Valve cover....
Old 01-12-2011, 05:40 AM
senix's Avatar
senix
senix is online now
Received 1,415 Likes on 1,010 Posts
what about an O2 sensor? I know there is a specific code for that but could it be a factor here?
GuitarJesus
06-11-2016 06:26 PM
GreaseGun Joe
10-15-2015 04:44 PM
dwimood
11-22-2011 02:20 PM
deejdeej
1983 - 2012 Ranger & B-Series
06-10-2010 09:51 PM
milowe
04-03-2009 03:17 AM
Quick Reply: DPFE Sensor location on Ford F250 2006
