Need Help with Exhaust Leak
I just finished a huge job of pulling the motor. I re-placing the bed plate gasket, HGs and installed ARP studs. I can't get the Y-pipe on each side of the motor to seal against the exhaust manifolds. I don't have any other exhaust leaks. Does anyone have some ideas on how do get the y-pipe to seal. Thanks!
I had the same problem after taking my exhaust manifold off to drill it for and EGT probe. I tried 4 different times to get it mated up, Ypipe first turbo last, turbo loose, manifold loose y pipe next, it did not matter how I did it. Eventually I over tightened the bolts to the point of bending the clamp on the y pipe, after that I really became frustrated. I replaced the y pipe because of the bent clamp. I still had a leak. The only thing I could figure was the exhaust manifold was out of round and I was too cheap to buy one. So finally I went down to the local muffler shop and gave them the inside diameter of the exhaust manifold and the outside diameter of the flare on the up pipe. I told him I wanted a metal crush gasket about 1/8 inch thick a hair bigger than the inside diameter of the manifold. He looked it up gave me a part number and sent me to Carquest to pick it up.
10,000 miles still no leaks. I actually just checked it again about 2 weeks ago. It may not be the recommended way but it is working great.
Sorry I cannot find the part number for the gasket or I would give it to you.
Found the bag. AP Part number was 8693
Here is a link to one from a web based vender.
AP EXHAUST Part # 8693
good luck
good luck
Installed the gaskets today and they helped with the exhaust leak. Should add post to the tech folder. Here are some pictures:
<center>
<a href="http://s556.photobucket.com/albums/ss5/holdendaniels/Exhaust%20Gasket/?action=view&current=IMG_2920.jpg" target="_blank"><img src="http://i556.photobucket.com/albums/ss5/holdendaniels/Exhaust%20Gasket/IMG_2920.jpg" border="0" alt="Photobucket"></a><br/><br/>
<a href="http://s556.photobucket.com/albums/ss5/holdendaniels/Exhaust%20Gasket/?action=view&current=IMG_2925.jpg" target="_blank"><img src="http://i556.photobucket.com/albums/ss5/holdendaniels/Exhaust%20Gasket/IMG_2925.jpg" border="0" alt="Photobucket"></a>
<br/><br/>
</center>
<center>
<br/><br/>
</center>
Exhaust leak at turbo
I pulled the turbo on an '03 6.0 to get down to the oil cooler now I have an exhaust leak at the intake side. Any suggestions? I cleaned the scale off of the turbo face and the face of the "y" pipe feels smooth. The mating joint looks tight and I've replaced the clamp.
Can I get a crush washer in this joint?
