6.2L V8 Discuss the 6.2L V8
E-85
Old 01-04-2011, 01:38 PM
PJOB2's Avatar
PJOB2
PJOB2 is offline
E-85
Any of you guys with the 6.2 try E-85? If so, how much did your MPG suffer and was there any noticable change in performance?
Old 01-04-2011, 03:22 PM
KaiserM715's Avatar
KaiserM715
KaiserM715 is offline
I have not heard any reports on a SuperDuty, but the Raptors are not rated to run E85.
Old 01-04-2011, 03:30 PM
PJOB2's Avatar
PJOB2
PJOB2 is offline
Mine has the "FlexFuel" logo on the back of the truck and the owners guide says that E-85 is one of the recommended fuels (pg 381). I thought all the 6.2 engines were FlexFuel. I guess not.
Old 01-04-2011, 04:33 PM
2000silverbullet's Avatar
2000silverbullet
2000silverbullet is offline
It does support E-85. There hasn't been many mileage reports that I've found with E-85 but here's a link to a post where someone mentioned a drop:
https://www.ford-trucks.com/forums/9...ml#post9399720
Searching for E85 in this forum turned up few results.
Old 01-04-2011, 04:43 PM
Thenewboss's Avatar
Thenewboss
Thenewboss is offline
I have been wanting to try it, but I haven't been able to find any between NE North Carolina, and Central PA. I would image between the slightly lower price and the slightly reduced milage it would be a wash in the end. I guess you could get a warm and fuzzy knowing you aren't putting out as much emissions.
Old 01-04-2011, 07:03 PM
postman524's Avatar
postman524
postman524 is offline
Wouldn't put that crap in my new truck if you paid me. The loss of gas mileage more than offsets the slightly lower fuel costs. Using ethanol in gas is the most moronic thing we have ever come up with. As far as emissions go, it's just as dirty just a different type of pollution than gas produces.
Old 01-04-2011, 08:46 PM
nycsteve's Avatar
nycsteve
nycsteve is offline
Its not really about emmissions, its about $$$$$$ for agricorp. Its all B.S.
Old 01-05-2011, 10:39 AM
Thenewboss's Avatar
Thenewboss
Nation & World | The hard truth about ethanol | Seattle Times Newspaper
FYI^^
I'm not trying to start an argument thread, I just know very little about E85 and this article is very educational for those interested.
Old 01-05-2011, 02:34 PM
krewat's Avatar
krewat
krewat is offline
Site Administrator
Let's not get into politics, or any other issues with Ethanol. The original poster wanted to know about MPG with E85. Let's keep it that way
Old 01-06-2011, 09:54 AM
1960's Avatar
1960
1960 is offline
PJ0B2 I have been running E85 in my truck from the day it was new last June I have 7800 miles on it now.
I really like the way it runs it feels like it has alot more torque than it has on reg gas.
I get around 9 to 10 mph with it short trips and around town. I get around 11 to 12 when I use reg gas in it.
I would not run anything but E85 in my truck.
I did get a tuner from Mike at 5 star and it did really bring the truck to life.
I have allways had Diesels before this I have had 7.3, 6.0, 6.4 and dodge cummins 5.9 and 6.7 I will not go back to a diesel after having this 6.2 gas.
I have a F250 CC 4X4 with 3.73 gears I also tow a 34' 11000# travel trailer
Old 01-06-2011, 04:58 PM
itherrkr's Avatar
itherrkr
itherrkr is offline
1960, how does it tow that trailer? Toy hauler by chance?
Old 01-06-2011, 05:17 PM
1960's Avatar
1960
1960 is offline
itherrkr
I live here in iowa so I don't get into the montains But for the hills around here and the flats it pulls as well as my Diesels did. I will run higher RPMs and will pull in 5th gear 50% of the time. But I will not go back to a Diesel After running this truck
If I went any larger with my camper I would go with the 4.30 gear.
My camper is 34" Holiday Rambler Pres. travel trailer with 2 slides
Old 01-06-2011, 05:51 PM
PJOB2's Avatar
PJOB2
PJOB2 is offline
Thanks for all the input. It sounds like performance doesn't suffer but mpgs do. Where i'm located, E-85 is only .20 less than 87 octane so from an economical standpoint, its probably a wash at best. I friend from Mn. said up there its .50 - .60 less than gas which would make it more tempting.
Old 01-07-2011, 09:50 AM
krewat's Avatar
krewat
krewat is offline
Site Administrator
If I remember correctly, the 6.2 running on E85 in the F150 puts out higher HP/torque numbers than plain gas. Why, I dunno, probably because they can play around with the spark timing and put more fuel in moreso than with gas, and still get good enough emissions numbers for the EPA.
mizzitch
Modular V10 (6.8l)
20
05-19-2023 02:56 PM
AB328
2015 - 2020 F150
24
01-05-2016 08:43 PM
Strokin-A-2010
6.2L V8
12-21-2015 12:20 PM
kpip
1997 - 2003 F150
16
09-16-2010 06:37 PM
radracing
08-04-2007 07:58 AM
Quick Reply: E-85
