8.8 rear disc brake swap
i was looking at putting rear disc brakes on my 87 F150 with the 8.8 rear end. My thoughts were IF the flanges line up, i was going to do a swap off of a 97 - newer F150 with an 8.8. i realize that i'm going to have to re-drill the rotor to fit the correct bolt pattern, but other than this and other minor nuances ( i think i'm going to have to run a 16 inch wheel) does anyone see any issues with this swap?? is there a better swap out there??
also found this too...8.8" 1984-96 Disc Brake Conv.
I was awaiting the "why not go drum" post ... simply put, i'm going autocrossing. I want to show imports that my old truck can haul more than lumber ...
on
Rear disks are far superior to drums..there are good reasons you don't see any drums on the newer trucks. From what I understand the parts from the Explorer 8.8 will bolt right on the F150 axle and of course the rotor has to be drilled for the larger bolt pattern, I have been wanting to do to my truck for some time now but haven't stumbled across the parts yet.
I didn't start a thread to discuss whether or not it's a good idea, i've already made up my mind to do the swap, i'm just looking for the right set of parts ...
As i stated before, my only concern with that setup is clearing the axle flange. if someone verified that i could do it with that setup, i'd be all over it! I'm kinda odd in the fact that i dont like going aftermarket when there's a factory swap out there, the main reason being when it comes time to replace a pad, rotor, or caliper, i don't need to go searching across the cyber universe to find it, i can go to my friendly NAPA store...
Maybe that one person figures if all wheel drums are good enough for a 80,000 pound semi, they are good enough for a pickup....
(I like all wheel disks on pickups, expecally if off roading, they work way better when wet then a drum)
