Dana 60 rear disc brake conversion
Old 12-24-2010, 09:13 AM
bigdan1979f-250's Avatar
bigdan1979f-250
bigdan1979f-250 is offline
What is involved in doing a drum to disc swap on a Dana 60 rear axle? Are there any aftermarket kits, or would I have to find hardware off of a newer model with a dana 60?
Old 12-24-2010, 09:39 AM
"Top Fuel" Bender's Avatar
"Top Fuel" Bender
"Top Fuel" Bender is offline
check the search box
I've seen a few threads on it when I was searching myself
Seems to be a few kits with mixed results of what works best
Old 12-24-2010, 10:04 AM
akforceten's Avatar
akforceten
akforceten is offline
here is a link '72-'79 Ford Dana 60
and here is a pic of my swap
hope this help you.
Old 12-24-2010, 10:16 AM
impalaslayer's Avatar
impalaslayer
impalaslayer is offline
good stuff, i wanted to ask the same question as i found several kits online but wasnt sure which to use. i also didnt want to make another thread on it but i couldnt find much during a search.
so other then the brackets, this kit uses standard GM parts?
Old 12-24-2010, 10:32 AM
akforceten's Avatar
akforceten
yes i used gm calipers and rotors from a 77 3/4 4x4 chevy truck.i also opted for the stainless steel braided brake line kit it was very easy to install.
Old 12-24-2010, 10:42 AM
impalaslayer
did you get the calipers through them or some where local? thanks for the info
Old 12-24-2010, 11:24 AM
akforceten's Avatar
akforceten
you can buy them though them but i got mine locally an saved about $100dollars in shipping
Old 12-24-2010, 11:26 AM
impalaslayer
good stuff man, thanks
Old 12-24-2010, 11:33 AM
akforceten's Avatar
akforceten
your welcome . i think its a great kit . I love finding things that give the best bang for the buck and this kit fits the bill !!!
Old 12-24-2010, 11:41 AM
impalaslayer
certainly seems like a pretty reasonable price for a win win item. i have to buy all new drums shoes cylinders, the whole nine anyway so why no go to something better and something that will preform better?
Old 12-24-2010, 01:12 PM
73 ford guy's Avatar
73 ford guy
73 ford guy is offline
he's right on the year rotors and calipers to use but as far as brackets go i made my own for free
I just used a piece of construction paper and made it work. The only critical thing is the hole centers and tapped.
I like this design so I could clock it perfect to allow the bleeder screw to sit vertical AFTER I rotated my diff up for my cv driveshaft. The axle points up about 20 degrees with my lift so i dont think a stcok bracket would of worked as well.
As for brake line stainless is nice but mine i searched through a brake line catalogue and found these from a 80's chevette car!! 10$ each and works great with enough length to still service pads.
As you can see its been sitting for awhile now...
This is actually a D70 rear axle but same thing. Even my diff cover was described to fit a dana 60 but I knew they interchange
Old 12-24-2010, 01:27 PM
73 ford guy
and now you need a parking brake!
This is what i use
its a mechanical ball valve line lock using brake pressure. Hold brakes on then twist valve.
It pretty badass.
I put mine here
It makes it easy to install and is in a good accessible spot.
I love it offroad on a hill i engage it, then with foot on gas and clutch i gas it on the hill then twist the line lok off so i have zero roll back and just go straight up.
Also on a tight corner i put it on, engage my twin stick t case to front wheel drive only, then crank wheel hard in direction needed then gassing it pivot off my back tires on a dime turning corner. Who does that in there 73 Dent lol
Old 12-24-2010, 03:30 PM
ChaseTruck754's Avatar
ChaseTruck754
ChaseTruck754 is offline
Here's a couple I have saved that show the part #'s etc. for the 8 lug trucks.
1977 Ford F250 4x4 - Dana 60 Disc Brake Conversion
https://www.ford-trucks.com/forums/8...sc-brakes.html
Old 12-24-2010, 07:11 PM
impalaslayer
This is what i use
It pretty badass.
I put mine here
thats pretty awesome lol. duno if id want it on a street truck but definitely a neat idea
Old 12-24-2010, 08:08 PM
Diesel_Brad's Avatar
Diesel_Brad
Diesel_Brad is offline
This is what i use
It pretty badass.
I put mine here
Yeah. those are illegal in any of the states i have lived in.
We call those micro brakes
Quick Reply: Dana 60 rear disc brake conversion
