Lost Power!!
Old 12-23-2010, 08:04 PM
Bwillden24's Avatar
Bwillden24
Bwillden24 is offline
Lost Power!!
I've been working on my '80 F100 for about a month and a half now and have been doing some great work for teaching myself as I go. Just recently my Bro-In-Law has been over and decided to work on my truck while I was out there and now I can barely get the truck to move. I think that all he did was fiddle with my carb, any ideas??
Old 12-24-2010, 09:25 AM
bertha66's Avatar
bertha66
bertha66 is offline
If he was messing with the carb, check the air mixture screw, turn it in to it stops, do not tighten, then open @ 2 turns and see how it runs. Did he change the timing?
Old 12-24-2010, 05:13 PM
Bwillden24's Avatar
Bwillden24
I dont think he did anything to my timing but I know he changed the vacuum line cluster around to nearly nothing.
Old 12-24-2010, 07:21 PM
Old93junk's Avatar
Old93junk
Old93junk is offline
Where did he hook the vacuum advance line from the distributor to?
Old 12-24-2010, 07:45 PM
Bwillden24's Avatar
Bwillden24
to the carburetor
Old 12-24-2010, 07:57 PM
Old93junk's Avatar
Old93junk
Make sure it is to the ported vacuum advance location and not just manifold vacuum.
Old 12-24-2010, 08:09 PM
Bwillden24's Avatar
Bwillden24
I am rebuilding my carb right now, then I'm going to check all vacuum lines and make sure they are in the correct spots.
Old 12-24-2010, 09:21 PM
Bwillden24's Avatar
Bwillden24
Carburetor disassembled, now to clean the whole thing up and make sure theres no gunk and put it back together
Old 12-24-2010, 09:24 PM
Old93junk's Avatar
Old93junk
Thats the autolite 1bbl right?
Ever think of going to a Offenhauser intake and a holley 3904bbl carb?
Old 12-24-2010, 09:35 PM
Bwillden24's Avatar
Bwillden24
its the motorcraft(carter) 1bbl, and no I haven't, i've just been trying to get my truck on the road, I found the label for my carb and got it cleaned off so I can actually read it, how do I depict what the model is from this:
EOTE CA
AO E 5
Old 12-24-2010, 09:41 PM
Old93junk's Avatar
Old93junk
Take it (metal label tag) down to Knechts, they will give you the right kit.
Should be a breeze, pay attention to the float settings.
Old 12-24-2010, 09:44 PM
Bwillden24's Avatar
Bwillden24
i already have the kit, all the pieces match up and so do the gaskets
Old 12-24-2010, 09:46 PM
Old93junk's Avatar
Old93junk
Your good to go then............just find a clean place to work, and good light.
I use the kitchen table, wife HATES it!
Old 12-24-2010, 09:47 PM
Bwillden24's Avatar
Bwillden24
heres what it looks like right now
Old 12-24-2010, 09:48 PM
Bwillden24's Avatar
Bwillden24
thats exactly what i'm using, parents weren't to happy but hey Its cold outside cant blame me
Quick Reply: Lost Power!!
