2004 f150 5.4 4WD won't engage (newbie)
Old 12-23-2010, 06:40 PM
drshort's Avatar
drshort
drshort is offline
I've spend the past couple of days reading every F150 4x4 problem post I could find. It's been a big help, but I'm still having some issues. I recently bought this 2004 F150 5.4 and the 4WD systems appears to need some care in multiple areas.
Problem #1 (Fixed): Transfer case engaging, but not disengaging 4 Hi / 4 Lo
A few days ago, I turned the switch to 4 Hi. It went into 4 Hi and light went on, but wouldn't come out when I switched back to 2 Hi. It turns out there is one relay to engage and another to dis-engage the external transfer case motor. (one relay does counter clockwise, the other does clockwise). I replaced both relays located under the hood and now the transfer case shifts in and out of great as it should. Fixed. I also replaced the transfer case motor, but that seems unnecessary in hindsight.
Problem #2: Wheel hubs (IWE) not locking.
When I am in 4Hi, it appears the front hubs aren't locking. I've read everything I could about the IWE system and replaced the solenoid on the firewall.
I pulled the vacuum lines at each wheel hub. I have strong vacuum on the passenger side when in 2 Hi and it goes away when I switch to 4Hi (as it should). The vacuum on the drivers side feels very weak. There must be a leak somewhere? Any place to focus on?
Vacuum keeps the hubs dis-engaged. So if I can turn off the vacuum by switching to 4 hi, why aren't the hubs engaging? Can the IWE actuators get stuck in the dis-engaged position? I've never heard any of the grinding or other noises people sometimes get on these front hubs, but who knows about the previous owner.
Any help would be greatly appreciated.
Old 12-24-2010, 09:50 AM
Greg B's Avatar
Greg B
Greg B is offline
It's possible for the IWE to be not engaging. If you read XJCAMARO69's writeups on the IWE system, I think nearly everything is covered on what to check.
Old 12-30-2010, 12:33 AM
drshort's Avatar
drshort
drshort is offline
Just an update n the 4wd not engaging.
Both IWE actuators were shot. One had a vacuum leak. This appears to have caused the other side to lose vacuum and grind over time causing the teeth to be very worn on both IWE and hub.
Old 12-30-2010, 05:50 AM
60DRB's Avatar
60DRB
60DRB is offline
...and to answer your question, yes the IWEs can fail internally. My right side IWE was actually broken/jammed. When I removed it there was a lot of dried burnt looking residue (used to be grease) inside it.
Old 12-30-2010, 11:18 AM
Greg B's Avatar
Greg B
Greg B is offline
Oh, how I long for the simplicity and reliability of the old fashioned manual locking hubs and manual transfer case on an F150.
Old 12-30-2010, 04:12 PM
60DRB's Avatar
60DRB
60DRB is offline
If only that stupid bee-a%#! hadn't run head-on into my good old '92 F-150... At least this new system is easy to repair.
Old 12-30-2010, 07:07 PM
xjcamaro89's Avatar
xjcamaro89
xjcamaro89 is offline
Its xjcamaro89.....just sayin, lol!
Old 12-30-2010, 08:52 PM
Greg B's Avatar
Greg B
Greg B is offline
xj, I assume everything is good with your truck now that you've done all the work on it.
Old 12-30-2010, 08:57 PM
xjcamaro89's Avatar
xjcamaro89
Ya, i think im good.
Old 12-31-2010, 07:23 PM
Greg B's Avatar
Greg B
Greg B is offline
Cool. Happy new year to all.
xjcamaro89
2004 - 2008 F150
447
01-31-2022 07:35 AM
WWR
02-25-2016 10:06 PM
Jxltrucking
1999 to 2016 Super Duty
01-04-2016 02:54 PM
nfazer
2004 - 2008 F150
12-07-2014 10:19 PM
Ranger Bob
2004 - 2008 F150
01-31-2014 05:35 AM
Quick Reply: 2004 f150 5.4 4WD won't engage (newbie)
