6.2L V8 Discuss the 6.2L V8
6.2L HP & Torque Difference
Old 12-22-2010, 06:06 PM
postman524's Avatar
postman524
postman524 is offline
Does anyone know why the 6.2 in the F150 is rated at 411HP and 434 FTLB's torque and the 6.2 in the F250 is rated at 385HP and 404 FTLB's torque. You would think that with the heavier duty truck in the F250, that Ford would have it reversed.
Old 12-22-2010, 08:08 PM
LSchicago2's Avatar
LSchicago2
LSchicago2 is offline
Different cams and a couple other small changes. That was done to increase power for the Raptor SVT off road truck. Kind of sucks that the get rid of the torquey V10 in the pickups, and the the Super duty doesn't even get the better version of the 6.2.
Old 12-22-2010, 08:53 PM
powerstroke72's Avatar
powerstroke72
powerstroke72 is offline
Part of the change was also because the Super Duty is rated for Flex-Fuel.
Old 12-23-2010, 02:22 PM
fg250's Avatar
fg250
fg250 is offline
also, those higher power ratings are with premium gasoline. with 87 octane they are the same.
Old 12-27-2010, 01:05 PM
LSchicago2's Avatar
LSchicago2
Not the same, with premium fuel adds about 10 HP according to Mike the factory engineer. More of the power is gained from the Raptor cams & other changes.
Old 12-30-2010, 10:16 AM
ordually's Avatar
ordually
ordually is offline
LS2 already pointed out the cam differences. I wanted to add that according to a Pickuptrucks.com article the chief engineer attributes most of the difference to rating differences in the over 8500GVWR class. Reminds me of Chevy rating their 6.0L lower in the 3500 than in the 1500.
The power numbers are larger in the light-duty pickup for two reasons, according to Chris Brewer, Super Duty chief engineer. "The main reason is that when the truck goes over 8,500 pounds [gross vehicle weight rating], the SAE [horsepower and torque] rating method changes," Brewer said. "We can't get the same horsepower and torque out of it [like we can in the F-150].” The 6.2-liter V-8 in the Super Duty also uses a different camshaft from the light-duty version, which, some may recall, is the same approach Ford uses to make 500 hp in the FR Raptor XT version of the 6.2-liter V-8.
Old 12-30-2010, 01:27 PM
LSchicago2's Avatar
LSchicago2
The difference in rating comes in at 10,000 GVW. 6.2 powered trucks over 10,000 GVW are only rated at 316HP @ 4179 RPM.
Old 01-05-2011, 07:44 PM
Gary Atsma's Avatar
Gary Atsma
Gary Atsma is offline
To clarify that further, the engine is the SAME whether under or over 10,000GVW, only the power levels are read at different RPM levels; 4179 RPM for over 10,000GVW, and the actual peak power level RPMs for under 10,000GVW; the difference being, noise regulations are different for the different GVW levels. You get the same engine either way; they are only measured differently.
Old 01-06-2011, 03:49 AM
fz1dave's Avatar
fz1dave
fz1dave is offline
Super Duty
I hate measurebaters.
Old 01-06-2011, 08:51 AM
Gary Atsma's Avatar
Gary Atsma
Good one! ;-)
Stepadery
2009 - 2014 F150
03-02-2016 03:10 PM
bigtexan99
07-17-2015 11:01 AM
kwrules
6.2L V8
05-11-2011 12:55 PM
MDSuperDuty
6.2L V8
16
01-16-2011 09:44 AM
todrobcon
1999 to 2016 Super Duty
22
09-23-2010 11:34 AM
Quick Reply: 6.2L HP & Torque Difference
