I own a Power Stroke 6.0 and it has a bully dog tripple power pup on it that i got from a friend and the chip is throwing five codes and it wont run it started loaping and then died i cant figure out what is wrong with it. the codes were P0113 IAT High input, P0403, P0603 ICM Kam (DL), U0630, and P1000 OBD reset (DL). Can anyone help me out thanks.
Welcome to FTE JerryG008 Did you buy this truck from a friend with the programmer or did you buy the programmer and install it on your truck? I would remove the programmer to eliminate any influence.
I bought the truck at an auction and the chip did not come with the truck. I also took the chip off the truck and tried to get it to start and it still would not start so i put the chip back on it to read the trouble codes and thats the codes that it threw. thanks for the replies.
P0113 and P0403 are circuit short to ground codes from what I read, so I would check the MAF and EGR part of the wiring harness around the drivers side front of the valve cover to start with. Possible you have a chaffing issue.
p0113 is iat1 make sure its pluged in correctly
p0603 is kam reset dont worry about this code
p0403 remove the egr vlave and check for it being stuck open
u0603 most likly caused by the bully dog
p1000 dont worry about this either. thats a pass without all moniters completed yet
