96 302 Firing Order
96 302 Firing Order
Hey all I got a question for you all about the firing order on my 1996 302 EFI - So I have been working on my truck for the past few months and and fired her up this afternoon for the first time in a few months - had the motor out to replace the oil pan and a cracked manifold and did a "few" upgrades in the process.
Anyways It stated up but was skipping really bad so I shut it down and we startd to look at things and I noticed the firing order I used and the one on the sticker on the radiator support are different - so I switched the firing order to the one on the sticker and fired it back up and she ran beautiful - so I'm thinking the one on the radiator support is the correct firing order but I checked both the Chilton and Motorcraft service manual and they are different then the sticker on the radiator support so what gives?
Here are the firing orders from both books for a 1996 5.0 Vin "N" 302:
1-5-4-2-6-3-7-8
Now here is the one from the sticker (and works):
1-3-7-2-6-5-4-8
Looking up the firing order on the sticker it's for a 5.8L 351 so says Chilton and the Motorcraft book - any ideas why the sticker on the truck and the books are different and anyone else run into this?
And the truck has a 302 and the VIN is "N".
Thanks,
Dave
1-5-4-2-6-3-7-8
1-3-7-2-6-5-4-8
Thanks,
Dave
Firing order is controlled by the camshaft grind.... So if engine has a different camshaft, firing order can change, also different years had different firing orders...
just depends on mfg of cam and model of cam... There are different schools of thought as to which order is best for a Windsor family engine...
Conanski - Thanks that makes sense then and matches the factory sticker on the radiator support which is what I ultimatly used. Just wish the books would note that somewhere.
Marios thanks that is the picture I was referring to and as Conanski pointed out it all makes sense now. Using the book it skipped with the 302 regular firing order. But using the firing order from the factory sticker on the radiator support it runs like it should. Never thought to see if the two matched - who would have thunk...
Thanks again.
As far as mod's just bolt on stuff - msd coil, new wires, msd cap (stock distributor), JBA shorty headers, Magnaflow y-pipe with high flow cats, and a Gibson cat back exhaust. I think that's it for engine mods.
Thanks again.
Thanks. Just so I am clear I have an 89 F150 with the 302 and about 256,000 so the old dawg is pretty tired. As long as the plug wires are on the correct cylinders the 351 will work, right. The other question I have is if the motor I found will work. It is a 96 model 351W complete from intake to oil pan. I was just wondering if it will work with my EEC-IV computer cause it is a roller motor.
