Oil Pan Removal
Old 12-15-2010, 05:32 PM
lakeman70's Avatar
lakeman70
lakeman70 is offline
Oil Pan Removal
Hello all. This may be a dumb question, but I was wanting to know if the oil pan on my 05 F350 6.0l can be removed fairly easily. Can I simply unbolt it and remove it?? I ask this question because this is my first diesel. I've removed several on gas motors in the past just need to know if the diesel is any diffrent. Thanks in advance, any input will be greatly appreciated.
Old 12-15-2010, 05:50 PM
2006powerstroke90's Avatar
2006powerstroke90
2006powerstroke90 is offline
I believe you have to remove the motor mounting bolts and jack the motor up slightly.
The more experienced ones with chime in, im sure.
Old 12-15-2010, 07:19 PM
cheezit's Avatar
cheezit
cheezit is offline
unbolt engine mount nuts at frame. lift engine 2" you may wisy to remove the fan shround to prevent damage. if you dont and you break something I will laugh .
unbolt the oil pan slide it back drop the pick up tube down and let if fall in the pan then slide the pan out.
Old 12-15-2010, 08:07 PM
lakeman70's Avatar
lakeman70
Thanks I had a feeling I would have to raise the motor. Was wishful thinking I wouldn't have to. I'm going to remove it because it is seeping oil. Would you recomend Ford factory gasket or is there a better aftermarket one??
Old 12-15-2010, 08:15 PM
cheezit's Avatar
cheezit
cheezit is offline
ford gaskets.
make sure to place something under the motor mounts so the engine does not fall before you want it to.
Old 12-15-2010, 09:12 PM
lakeman70's Avatar
lakeman70
Cheezit, really appreciate all your input. It will make things go smoother.
Thanks
Old 12-16-2010, 09:29 PM
holdendaniels's Avatar
holdendaniels
holdendaniels is offline
Pay attention to the bolts, they are not all the same length. There are long bolts that go in the front and rear of the oil pan.
Old 07-19-2011, 11:30 AM
greezy_jeans's Avatar
greezy_jeans
greezy_jeans is offline
ok guys i made a rookie mistake, mixed up the long and short bolts, forgot where the long ones go. can anyone help me with this i know front and back but i dont remember exactly.
Old 07-19-2011, 11:40 AM
69cj's Avatar
69cj
69cj is offline
Take a long bolt and try it in each hole hand tight. You should be able to tell which ones take the short bolt.
Old 07-19-2011, 05:13 PM
cheezit's Avatar
cheezit
cheezit is offline
3 go in the front just watch the holes you put them in and 2 go in the back of the pan in the center
Old 07-20-2011, 08:49 PM
Skinner F350's Avatar
Skinner F350
Skinner F350 is offline
where did you place your jack or did you use a picker.
Old 07-20-2011, 08:53 PM
cheezit's Avatar
cheezit
cheezit is offline
using a floor jack is a bit on the unsafe side... been there done that. use a block of wood under the balance. once the motor is up use something as a support under the motor mount. do not stick your fingers or hands any were they can be crushed while doing this. I use 2 large sockets wuth extensions as handles so I dont stick my hands in the wrong place.
Old 07-21-2011, 08:19 AM
Skinner F350
sounds good. Thanks
Old 07-21-2011, 09:05 AM
69cj's Avatar
69cj
69cj is offline
What's the balance or am I reading this wrong?
Old 07-21-2011, 09:16 AM
BPofMD's Avatar
BPofMD
BPofMD is offline
Received 1,076 Likes on 978 Posts
Looking at the keyboard, I'm sure he meant Valance......
Quick Reply: Oil Pan Removal
