vacuum amplifier repair
Old 12-11-2010, 07:56 PM
zaaac's Avatar
zaaac
zaaac is offline
I'm working on getting my egr operational in hopes of better fuel economy. All components were in working order except the amplifier. One of the diaphragm's was ripped so I picked up a second one and it had the same problem. I'm thinking this must be a common problem so figured I would try and fix them. I'm sure I could get the egr working without it but think it'll be better with the amplifier.
Here is the vacuum amplifier.
Here is the problem. The black diaphragm is ripped right off the little brass orifice. It should be pressed underneath therefore sealing up both sides separately.
I'm gonna patch it and re-press it under the orifice. You can drive out the orifice with a small nail or punch. Doesn't take much to pop it out.
One small tap and it's out. You can see the part of the diaphragm that was pressed underneath.
Next rough up the diaphragm where the patch will be glued on. I used 180 grit emery cloth.
Then apply rubber cement and let dry. Only takes a couple minutes to dry.
Press on patch.
Back side.
Poke hole in center with a nail.
Push orifice through diaphragm and trim rubber away so it wont fold up under the orifice when you press it back together.
Ready to be pressed back together.
Light tap with the hammer and it's pressed in.
Ready to be screwed together.
Check to make sure it holds vacuum.
Two vacuum amplifier's ready for service.
I hope this will help someone get their egr working like it should. Tomorrow I should have it hooked up, carb leaned out and timing re-curved. I will let you know how I make out.
Old 12-11-2010, 08:23 PM
fmc400's Avatar
fmc400
fmc400 is offline
MSEE
Thanks for sharing this. Reps sent.
Old 12-11-2010, 09:53 PM
ctubutis's Avatar
ctubutis
ctubutis is offline
Ditto, that's a great write-up!
Old 12-11-2010, 10:26 PM
Bullitt390's Avatar
Bullitt390
Bullitt390 is offline
Certified Thread Hijacker
Nice!
Josh
Old 12-12-2010, 11:05 AM
jagabom's Avatar
jagabom
jagabom is offline
Excellent work zaaac. This should be kept somewhere on the site. How did you know the vacuum amplifer was toast?
Jim
77 F150 - 400 CI
Old 12-12-2010, 12:21 PM
zaaac's Avatar
zaaac
zaaac is offline
Port S and V should not commingle. If they do the diaphragm has a hole in it. All you need to do is blow in one of the ports and air shouldn't come out the other port. If the diaphragm is ripped it wont be able to open the valve and allow vacuum to pass through port R and O on the opposite side of the amplifier and then to the egr valve. When vacuum from the spark port on the carb is greater than vacuum from the venturi port on the carb the amplifier valve is opened allowing vacuum to the egr. Also between the amplifier and egr is a load control valve. It dumps the vacuum to the egr when venturi vacuum is present. I'm assuming all this complicated stuff is supposed to close the egr valve during idle and full power. I've been studying this for the past week but still don't have a complete grasp on it. Time to go to the shop and hook up vacuum lines. Wish me luck. Here is the diagram I'm gonna follow and a picture of the load control valve with amplifier.
Old 12-12-2010, 03:31 PM
Nathan Plemons's Avatar
Nathan Plemons
Nathan Plemons is offline
Excellent write up. I would be curious to see how it affects your mileage. My EGR doesn't do squat as the plate is damaged and clogged up and so too does the intake seem to be. I really didn't care but if it could actually improve the mileage I might look into it.
Old 12-12-2010, 05:52 PM
zaaac's Avatar
zaaac
zaaac is offline
Everything's hooked up and egr is working. Bumped timing up to 10° from 6° and no pinging. Use to ping with anything over 6°. Tried hooking up the vacuum advance and it started pinging. I can't figure that one out. It has a 26° reluctor so I should have 36° total. I don't have a tach but revved it pretty good and it only went up to 20°. Might try some weaker springs. Pulled out a spark plug and it was black(dry). I had 59 jets and dropped them down to 51. Now it misses on acceleration so will put in some 57's. Probably will still be rich so need to find some 53-55 jets. What do you guys have in your carb? Not sure how to check power valve vacuum but doesn't seem like it is leaking. I have 3 of them but not one has a color code on it. I'm sure I will improve my fuel mileage but now have done so much I will never know how much the egr helped. I guess it all works together though.
Old 11-23-2013, 09:09 PM
TexinCali's Avatar
TexinCali
TexinCali is offline
I know this is an old thread but I had to send reps! What a great write up, worked like a champ. I would not even have know there was a diaphram in this thing and mine was ripped exactly as shown!
Don't even know if the original poster is still around if so NICE JOB!
Old 03-22-2014, 10:59 PM
lbcarguy's Avatar
lbcarguy
lbcarguy is offline
Vacuum Amplifier
Thanks so much for this post. I repaired my amplifier today. It failed exactly the same.
Mike
t.r.c
1978 - 1996 Big Bronco
24
08-14-2016 11:03 PM
mankypro
12-28-2013 09:11 PM
mankypro
28
12-28-2013 09:05 PM
93hatch
26
10-04-2012 06:33 PM
bondomerchant
23
05-13-2009 08:42 PM
Quick Reply: vacuum amplifier repair
