Where is serial # for my '04, 6.0l engine
Old 12-08-2010, 10:50 AM
RickBraden's Avatar
RickBraden
RickBraden is offline
I tried to use the "Search" funtion on the website but can't find where to look for the Engine serial number on my 6.0L. Thanks & good day.
Old 12-08-2010, 11:23 AM
High Binder's Avatar
High Binder
High Binder is offline
Mine was one a sticker on the valve cover under the FICM.
Old 12-08-2010, 01:53 PM
RickBraden's Avatar
RickBraden
Engine Serial #
So you had to remove your FICM to read it? Thanks, Rick
Old 12-08-2010, 02:38 PM
High Binder
I think you can see it by just moving the degass a little out of the way. It's been a while though so I'm not 100%. Why do you need that number? I only needed it once when a dearlership arts guy couldn't figure out his *** from a hole in the wall. I ended up figuring it out here on the forums.
I'll go look at mine real quick for ya.
Old 12-08-2010, 02:44 PM
High Binder
OK it's ona sticker on the FICM under the degass, I can almost read mine but to really see it I would have to move the degass or get a small mirror. Mines an early 2004 so it has the late 203 motor.
Old 12-08-2010, 03:54 PM
RickBraden's Avatar
RickBraden
Ebgine VIN
I wanted to know the Serial # to tell what year engine is. Sometimes when I read the 6.0 L bible from this website they may say, a
part has been used or only used on engines before or after a certain date. I thought that would help me when I want to order an egr delete kit etc & they ask me about the date or build etc. Thanks, Rick
Old 12-08-2010, 04:03 PM
npccpartsman's Avatar
npccpartsman
npccpartsman is offline
The easiest way to tell on an 04 is to look at the passenger side valve cover. If there is a sensor (ICP) in the top front end of the valve cover it's an 04 and has a square EGR cooler. If not it's an 03 with a round EGR cooler and the ICP is under the turbo.
Old 12-08-2010, 04:09 PM
High Binder
Ah I see, I think the est way to tell what you really have is to look at the EGR cooler like ncparts said and see if it's round or square. Round is early '04 build and square is after 9/30/2003-ish.
Old 12-08-2010, 06:17 PM
RickBraden's Avatar
RickBraden
Thanks, now I remember about the '04 with the square egr cooler. Thanks a lot. I try to do all the PM's that I'm suppose to do. It's paid for & the paint looks new. I want to do egr delete so I don't have crap going back into engine. Thats why I'm doing CCV with Racor 4500. Bye
ed foster
07-26-2016 11:30 PM
dclarkson
1983 - 2012 Ranger & B-Series
12-24-2011 08:20 PM
drewdog
1999 to 2016 Super Duty
07-24-2009 10:10 AM
johncardi
07-13-2009 03:29 AM
60f100trk
07-01-2001 06:18 PM
Quick Reply: Where is serial # for my '04, 6.0l engine
