1983 - 2012 Ranger & B-Series All Ford Ranger and Mazda B-Series models
2011 ranger tire size
Old 12-07-2010, 01:49 PM
Xistenz's Avatar
Xistenz
Xistenz is offline
Looking at buying a new ranger but I am wondering what is the largest tire size that will fit on one without rubbing. A 2011 4x4. Going to be leasing it so not doing suspension mods and using the stock wheels. Thanks.
Old 12-07-2010, 10:20 PM
ranger pat's Avatar
ranger pat
ranger pat is offline
Ignore this post, I see from above that it will be a 4x4.
Old 12-07-2010, 10:43 PM
g_k50's Avatar
g_k50
g_k50 is offline
proper tire size listed on door tag, door tag created by certified SAE.
Old 12-07-2010, 10:52 PM
Bidwell's Avatar
Bidwell
Bidwell is offline
Door tag lists the largest tire size that will fit without rubbing?
Old 12-07-2010, 11:16 PM
g_k50's Avatar
g_k50
g_k50 is offline
I can't just write yes.
Old 12-07-2010, 11:28 PM
grandmas77f150's Avatar
grandmas77f150
grandmas77f150 is offline
You can fit a larger than stock size without rubbing under normal driving conditions.
It's when you go offroad that you will see rubbing
Old 12-08-2010, 09:06 AM
ranger pat's Avatar
ranger pat
The stock largest tire accounts for fully loaded vehicle, really rough road, sharp turns, steep inclines, etc. If you never intend to do any on these things, ask your local tire store what they recommend. Store your stock tires as they will have to be put back on when you turn in the lease vehicle.
Old 12-08-2010, 01:34 PM
ducatdre's Avatar
ducatdre
ducatdre is offline
You should leave the stock tires on, because if you do plan to go off road, it will cause the larger tires to rub. You could probably get same size tires but with a different tread.
Old 12-08-2010, 04:31 PM
grandmas77f150
I have larger than stock tires, when I've gone offroad I haven't rubbed. Granted it's only one or two sizes larger
roshteaux
2011 to 2019 Explorer
07-11-2017 11:34 AM
La-man
2009 - 2014 F150
09-15-2016 11:28 PM
hotrod45
1999 to 2016 Super Duty
08-17-2016 12:15 PM
Willl
03-20-2016 01:58 PM
Thenewboss
17
07-30-2012 12:06 AM
Quick Reply: 2011 ranger tire size
