99 v10 f250 oil ?
The V10 likes thinner oils. I think it also calls for a 5W-20. It's known to shear oils down and still return great wear results. Do not put that Lucas stuff in your engine. It's a waste, there are no additives in it or anything. If I was you, I'd run a synthetic 5W-30 in it. 0W-30, 5W-30, 10W-30.. they all are 30 weights at 212F. Which is average operating temperature for vehicles. W means Winter, actually, and refers to cold flow/pump ability. Castrol Syntec *Made In Germany* aka German Castrol is 0W-30. It's one of the thicker 30 weights, too, and very shear stable.
5w30 and even 5w20 modern oils are stout. You need to have ZERO worries that these oils are two "thin" especially for a '99 V10 like yours.
We have a fleet of medical transport buses, Fords with the V10s. Hot, California valley summers, 100 degrees plus for a week or more. Stop and go driving. Freeway runs with the AC blowing cold at all times. They use nothing BUT 5w30 or 5w20 oil with ZERO repeat ZERO oil related issues or oil "breakdowns". Your V10 will never come close to this type of driving conditions, even in hot, humid Georgia.
Your truck is perfectly safe with what Ford recommends, and if you want to achieve the best possible MPG in your truck, use what Ford recommends. I want to spend less at the gas pumps, not more.
To think that in today's world you must use one oil in the summer and another in the winter, is obsolete and extremely "dated" thinking. If you live in Alaska, or Canada, up in the Yukon ect. then you might want to rethink winter conditions. Even in that case, you would be thinking; 'should I run a 5w30 or 5w20 full synthetic oil'?
Peace, Ed
PS You only need the Lucas additive, if your V10 is worn, very high mileage ect. If your V10 is normal, tight ( little to no oil consumption at 120,000+ miles) don't use the Lucas. It's not needed or warranted in that case.
Peace, Ed
ford recommened 5/30 in the v10 untill 2004.
Using 5w-30 is fine for the OPs 99'. I wouldn't contaminate the oil with the Lucas additive. If you got a lawnmower with worn rings use the Lucas in that.
