6.2L V8 Discuss the 6.2L V8
What do your trans temps run?
Old 12-02-2010, 10:00 PM
saratoga2011's Avatar
saratoga2011
saratoga2011 is offline
Mine is running 190-196 on the highway at 70 with the cruise set and OAT's in the low 50's. Is that in line with others? It's freaking me out now because it revved up between the 1-2 shift tonight.
Also asking because the 06 Duramax I had ran 165-170 unless it was in the 90's and I was driving in heavy stop-and-go traffic.
Old 12-02-2010, 11:30 PM
fz1dave's Avatar
fz1dave
fz1dave is offline
Super Duty
Sounds normal. I was at 192 coming home from work at 4am yesterday. Air temp was 23F.
Old 12-03-2010, 12:36 PM
LCPullman's Avatar
LCPullman
LCPullman is offline
I wonder if if has anything to do with the gas v.s. diesel. I have a big block with the allison, and the trans temp runs noticeably warmer than on my duramax.
Old 12-11-2010, 05:35 PM
GLC's Avatar
GLC
GLC is offline
Mine runs 190-198 pretty consistently. Had it since May so I've ran it through the summer months too. Even pulling my Kubota up hills (About 5,000 lbs+trailer,) it never went over 198. Takes a while to get up to temp lately, been in the 20's and 30's lately here in PA.
Old 03-28-2011, 05:22 PM
HillHunter's Avatar
HillHunter
HillHunter is offline
Mine runs 190-195 pulling something or not.
Old 04-14-2011, 05:54 PM
Sargemo105's Avatar
Sargemo105
Sargemo105 is offline
Everytime I've checked its running at 198 on the nuts. I have yet to pull anything so the temps are with no extra loads on the truck. Note: just on my second tank of gas.
Old 04-17-2011, 10:11 AM
iggy2's Avatar
iggy2
iggy2 is offline
I know this question was asked awhile ago but I have some new data.
I just returned from a 700 mile trip pulling my 30ft 5th wheel. (approx 10,000 lbs) and I had the following transmission temps.
Transmission takes at least 5 miles to get up to 165-175 degrees.
Transmission temperature ranged between 184 – 199 degrees during my trip.
The higher temps were climbing large hills at highway speeds of 55-65 mph.
Some interesting facts were that the transmission temp did not rise when climbing and transmission kicked down to 5th or even 4th gear. That just shows that the cooling system is good. Oh outside temps were between 80 and 85 degrees during climbing. I live in Arizona.
So in conclusion the 189-199 degree transmission temps are normal range.
Old 04-25-2011, 12:13 PM
stuffdeer's Avatar
stuffdeer
stuffdeer is offline
My temps run between 189 to 198.
However, towing my trailer in heavy traffic stop and go, I can get it to reach 210. I've had it touch 214.
Old 05-08-2011, 07:28 AM
iggy2's Avatar
iggy2
iggy2 is offline
I just finished a long run with my trialer (2,800 miles) and my temp ranged from 189 on the low end and have gotten it up in the 208 range heavy pulling up hills once. Th outside temp. was over 90 degrees.
Average running flat towing was 189-192 degrees.
Nice Work Truck
06-03-2013 12:52 AM
jdadamsjr
03-20-2011 08:27 AM
Gordon Freeman
08-30-2010 05:03 PM
hanklin
09-14-2009 06:24 PM
3broncocrazy
Georgia Chapter
06-10-2005 06:39 AM
Quick Reply: What do your trans temps run?
