Headlights flicker
Headlights flicker
My 2002 F150 Supercrew headlights have begun to flicker at approximately 30-45 second intervals. I haven't noticed if any of the interior lights also flicker or if the volt meter changes when it occurs. The alternator appears to be charging since I checked it while running. Any advice?
The battery charge reads 14.5v when the engine is running so the alternator must be ok. I checked the volt guage when the lights flicker and did not notice ANY drop/change when the flicker occurs. Could it be the aftermarket fog lights or a ground strap problem? The fog lights have never caused a problem in the 5+ years they have been installed?
on
In older Fords the culprit was the headlight switch assembly.
It had a circuit breaker that would cause a flicker.
I'll have to see if that is still a possibility.
http://www.35thatr.org/Tips/HeadlightsFlicker.htm
I believe that I may have solved my flicker issue. I was also having an issue with the ABS light occasionally coming on. I finally found that the right front ABS sensor was touching the exhaust manifold and melting/possibly shorting. I replaced it and my ABS problem disappeared. Now that I have driven it at night the flickering also seems to have cleared up.
davidpa28140
07-27-2017 05:26 PM
jackzisakis
03-28-2017 09:29 AM
mountain dewd
26
07-16-2016 08:55 PM
explorer1999
05-20-2002 03:23 PM
