1992 F-150 2WD to 4WD conversion
on
Hey Jas88 how bout some pictures! Did you swap bronco parts into a 87-91 f150? They are different front driveshafts?
Pics I can get this weekend, it's dark here when I get home from work.
Then figure out what it would have taken to fix the truck you cut up. It was cheaper wasn't it? You bet it was, and now you still only have 1 truck. Get my point?
on
BTW, don't forget to rebuild that front axle, new ball joints, and brake stuff, etc.
If you only replace the stuff that needs it, you can cut your costs quite a bit. I put new rotors, brake pads, bearings and seals on the front end and that was it. The bushings and ball joints I kept and I used my existing tie rods and drag link and such.
Holy crap. I didn't expect this many replies LOL. I have a major lack of knowledge on the mechanics involved with cars but could easily do the bolt on stuff myself. Anything to do with the tranny I think I'll bring to a shop to have done. I don't have the money to completely re-do all of the suspension and everything. I am only looking at doing what needs to be done so that it is a functional 4x4. Like jas88 stated, I just can't give up this truck. It would never sell for what I have put into it, especially because it's only a 2WD. I was expecting to hear that "sell it an buy a 4wd" statement, but this truck has 170,000 on it and everything runs perfectly on it. I don't want to end up buying a different truck only to run into problems with it. Anyways, pictures from those who have done it would be great.
My post was not meant to discourage you, just to merely suggest that you carefully reconsider the option of just making the 4x4 donor run good and drive it when you need a 4x4. BTW, Jas88 I have a rather long ongoing relationship with the first truck I ever bought, it's a 1970 C-10 long wide that is at the moment my daily driver. Also with a flatfender Jeep sitting in the yard.
on
When I decided I wanted a 4x4 I weigherd the options for turning it into a 4x4 and then went and bought one. Just like I told him to. By the time you get done finding all of the parts to make the swap and figure in your time to do it (which is something) you will just about always end up money ahead to go buy a 4x4. Doesn't matter how good of shape your 4x2 is in.
Jas, That is an AWESOME Truck!
How did you go about raising the front end? Or does it just raise itself after the swap?
Do you think you could come up with a list of everything that needed to be done to convert it to 4x4? If there's too much, I understand haha.
on
1) M5OD transmission for 4x4
2) BW-1356 manual shift xfer case + wiring harness
3) xfer case shifter and boot
4) M5OD rear crossmember for 4x4
5) 3.07 gear Dana 44 TTB + new brake rotors, pads, and bearings
6) Used driveshafts that I had cut down to fit and balanced + new u-joints
7) Raybestos alignment bushings for TTB
8) Extended length brake hoses - got them on RockAuto.com for an F350 @ $7 each
9) 1" blocks for rear-end and longer u-bolts
10) Speedo cable for 4x4
I probably forgot a few odds and ends like new shifter ball, gasket between xfer case and trans, stuff like that, but I tried to hit all the major stuff. Like I said, I swapped for a lot of this stuff and paid very little for what I did buy. I was adding it up in my head and I think I spent about $450 or so on everything. I have my 4x2 ZF on CL right now for $350, so I won't break even but I might be out of pocket only $100-$150.
#30
