Dieselsite coolant filter warning/fix (with pics)
#106
#107
Thanks ZMANN,
I will be replacing that soon. Do you know what that part is called or know where i can find a part #? If not, I'll just run up to the dealer and show them, and get the part along with a new hose....looks like it will be a good time to go ahead and put in the new brass T as well.
Good to hear, on both counts. I don't plan to replace mine until my next coolant change, unless something happens sooner.
#108
#109
Fellas,
I did some more investigating on my coolant leak. I think i found the culprit, take a look at this pics
Ford Truck Enthusiasts Forums - Jayybird's Album: Coolant Leak
[snip]
I checked my coolant leve and it was 1+" below the MIN line ( i had filled it up to the MIN line with the truck sitting in the same spot a while back).
Also, i checked all the coolant filter connections, hoses, degas cap, and I can't find any trace of coolant leaking in those places.
So what do yall think?
[snip]
#110
#111
I would do it ASAP, mine was good and solid until it wasn't and when it wasn't was on the side of the road and $30 worth of coolant covering everything in my engine compartment.
#113
Maybe I'll do it when I change my filter. I've got about 6 months on the original and it still flows well. Seems my system is a clean one.
#115
#117
check this against the oem price \\
http://www.dieselsite.com/index.asp?...ROD&ProdID=473
THANKS!!
I just called my local stealer and that heater control valve assembly is $76. I think I will save a few bucks and try the diesel site one.
THanks again!
#118
I beleive it is an oem unit
I thing partsguy Ed can get them at a better $ also but I don't have his info EDIT https://www.ford-trucks.com/forums/member.php?u=406391
#119
1) Trip to Lowes - $7.00
2) Getting out of cleaning the house when you wife asked for help - duh!!!
3) Working on your Ford Super Duty - Priceless!!!
