Dieselsite coolant filter warning/fix (with pics)
#91
#94
I have never had a problem with brass fittings, there is nothing to go wrong with them. We started to use the plastic ones, because they are much cheaper, but have had alot crack. So we no longer use the plastic pex fittings.The extra cost of brass is far less then the cost of someones home,and property. Now this is in the plumbing end of pex, but I see no way there will ever be a problem with the brass in the 6.0 cooling system.
#95
I checked my coolant level again this morning after truck sat all night. Yep, she was about 1" below the min line..appears i have a problem. Well, I started inspecting the connections at my coolant filter. I noticed some white residue around inlet/outlet at the filter. I posted some pics here, Ford Truck Enthusiasts Forums - Jayybird's Album: Coolant Leak
I looked around the T fitting and can't really tell if any is leaking there, but it is real tight in there.
My truck is running great, Temps are good (maybe a little low), i don't do any crazy hot rodden or towing. When the truck is warm, i notice the coolant level rises in the degas bottle but not quite to the top so i don't think she is puking out the cap. I had ARPs and gaskets installed 20K miles ago, so i don't think its a gasket issue. I am hoping its just my coolant filter system. I plan on getting the brass t-fitting like what has been suggested on this thread, also, i will disconnect and clean up everything good and make sure its put back correctly on the filter.
What else can i trouble shoot for leaking coolant? Damn i don't want any problems, hopefully its just at this filter system and i can fix it.
Thanks
#96
First thing to do is to watch it for a while. If it really is leaking it will get lower and lower, and then you'll know. Once you are sure it is leaking, then maybe turn off the valves to the coolant filter and see if it stops.
#97
#100
I'm sure you know where it is likely going. So I won't speak the dirty language.
#101
Watch it when you start it in the morning for white smoke and smell the exhaust.
One other thing about coolant level in the bottle. Parking on a slight elevation change can make the level easily move 1/2" either way. I'd closely monitor and record how much coolant you were losing over time and be precise with every aspect of your "study".
#102
Fellas,
Thanks
Thanks
My coolant level varies from time to time and the slightest incline (not perfectly level) makes a difference when looking at the degas bottle level.
If your really concerned.... have your system pressure tested... have a manual pressure pump installed on the degas bottle cap and pressurize to max pressure and let it sit... and see what happens (does it hold or loose pressure... or does coolant leak out somewhere)?
On a side note... my levels vary from day to day and always have... do I know why... no... but they do go up and down depending on ambient outside temps, driving style, engine temps and the like... so that may be the variable at play with your motor???
#103
Fellas,
I did some more investigating on my coolant leak. I think i found the culprit, take a look at this pics
What is that part? What is it for? Does it leak often?
You probably can't tell, but the photo where you see my fingers acutally had coolant seaping out. ( i assume it was coolant).
What is that gray wire thing for? That usually falls off and I have to plug back in.
I checked my coolant leve and it was 1+" below the MIN line ( i had filled it up to the MIN line with the truck sitting in the same spot a while back).
Also, i checked all the coolant filter connections, hoses, degas cap, and I can't find any trace of coolant leaking in those places.
So what do yall think? Is it an easy fix?
Thanks for any input..you guys are the best!
#104
#105
Thanks ZMANN,
I will be replacing that soon. Do you know what that part is called or know where i can find a part #? If not, I'll just run up to the dealer and show them, and get the part along with a new hose....looks like it will be a good time to go ahead and put in the new brass T as well.
THanks!
THanks!
