6.2L V8 Discuss the 6.2L V8
Super Tube 6.2L Intake
Old 11-27-2010, 10:02 AM
5 Star Tuning's Avatar
5 Star Tuning
5 Star Tuning is offline
Former Vendor
Hi Guys
I thought i would share we have been working on this concept for Super Dutys and Raptor 6.2L intake..
Old 11-27-2010, 10:08 AM
drh1175's Avatar
drh1175
drh1175 is offline
Looks great! How does it compare to the OEM? I am getting my new 6.2 soon and am looking for something up that alley!
Old 11-27-2010, 10:16 AM
LMS Residential's Avatar
LMS Residential
LMS Residential is offline
Damn Mike, did nearly identically the same thing to my 5.4 only I shot it in black hi temp enamel.
In particular I like the wump sound when you step into it. Might be my wishful thinking but there seemed to be a little more get up in higher rpm ranges like 3 - 5000.
Old 11-27-2010, 10:27 AM
5 Star Tuning
Former Vendor
Thanks guys, Stock tube at maf is 80 mm ish.. this tube would be 89 mm with a dry filter on the end...
Old 11-29-2010, 07:08 AM
devongarver's Avatar
devongarver
devongarver is offline
What are the functions of all of the factory hoses that are connected to the intake tube? I know there is usually one that is connected to the valve cover as a breather, but I thought I saw a few others, and I haven't followed them yet to see where they go.
Did you retain all of these when you did this kit? I have had issues before of getting oil in the intake and have wondered about just putting a breather filter on the valve cover fitting to avoid this. Is there any harm in doing that?
Old 11-29-2010, 07:46 AM
5 Star Tuning
Former Vendor
there are no pcv or other hoses on factory tube... those are all attached to the center box.
Old 11-29-2010, 09:53 AM
devongarver
Gotcha, I will be removing that center box though when I do mine. Do you think I would be OK to use a breather filter on the valve cover?
Old 11-29-2010, 11:22 PM
socapots's Avatar
socapots
socapots is offline
looks good man.
Old 12-05-2010, 12:34 PM
5 Star Tuning
Former Vendor
A few more shots before powder coating of pipe and before this thing is avail to public. We will also be working on a lid option too. Intake would work on all 6.2L Super Dutys and all 6.2L Raptors.
Old 12-05-2010, 06:32 PM
Gary Atsma's Avatar
Gary Atsma
Gary Atsma is offline
I think you would mess up the PCV system by doing that. You shouldn't have any oil in the intake if everything is hooked up right. Don't try to out-think the engineers on stuff like this. They have these emission systems pretty well figured out. I'm NOT saying things can't be improved (witness the above system), but you have to think everything through a lot more than in the not-so-distant past.
Old 12-08-2010, 02:27 AM
eticket's Avatar
eticket
eticket is offline
Mike (fordmdb)
Would this intake require a reflash or does ford PCM have "learning" ability?
I noticed you removed the factory resonators. Is the engine intake note comfortable
during normal driving and cruising? Thks...
Old 12-08-2010, 09:18 AM
5 Star Tuning
Former Vendor
Originally Posted by eticket
Mike (fordmdb)
hi eticket
I would recommend running a tune with any intake to take advantage of the modification. This one would be no different. Most intakes on the market use larger diameter tubes that tend to lean out fuel strategies. The larger tube also alters the maf function which in turns alters when to deliver fuel and timing to the engine. A calibration / tune is the only way to correct for this.. however with that said the PCM does have adaptive learning to help correct the lean condition but only up to a point.
As for sound, In cruising mode this intake has better than stock throttle response and is as quiet as stock and once you step down on it comes on strong with a louder than stock sound but again no problem with cruising sounds.
5 Star Tuning
6.2L V8
36
04-27-2014 07:59 PM
5 Star Tuning
6.2L V8
21
10-11-2011 05:26 PM
5 Star Tuning
6.2L V8
23
03-22-2011 08:24 PM
5 Star Tuning
5.0L Coyote
199
03-21-2011 06:36 AM
5 Star Tuning
6.2L V8
10-12-2010 07:01 PM
Quick Reply: Super Tube 6.2L Intake
