2010 F150- P2135 DIAGNOSTIC CODE
Old 11-20-2010, 03:41 PM
dwalls56's Avatar
dwalls56
dwalls56 is offline
I HAVE A 2010 F150 THAT HAS DIAGNOSTIC CODE 2135- AND SAID TPS PEDAL POSITION SENSOR/SWITH A/B VOLTAGE CORRELATION.... ANY IDEAS???????
Old 11-20-2010, 07:04 PM
$Simpleman76's Avatar
$Simpleman76
$Simpleman76 is offline
I can't say about the f150 but i did just change a pedal position sensor on a GMC sierra, the part was 50 dollars and took about 20 minutes, the sensor is mounted on the side of the pedal assembly, some sensors include the pedal and all and some are just the sensor, if I am not mistaken the ecu sends a reference voltage to the sensor and as you apply more or less pressure to the pedal the voltage coming out of the pedal sensor changes the voltage going back to the ecu and the ecu then drives the throttle actuator accordingly, the reference voltage is 5 volts on the gmc, as far as the channels i would guess that there is two channels going to the ecu and it does a comparison of the two voltages to make it's decision on the actuator position, take this information for what it is worth, it was on a gmc but I would assume that the ford system is similar in operation, I would say it would be a warranty issue and they should fix it for ya, so basically the pedal position sensor is now what the throttle cable used to be, kind of scary if you ask me, because I kind of like to rev the motor of my old fords with my hand while under the hood, I guess those days are long gone now
Old 11-20-2010, 07:31 PM
shotgunz's Avatar
shotgunz
shotgunz is offline
Head to the dealer. It will be covered by your warranty.
And please do not use ALL CAPS. It makes your post difficult to read.
Welcome to FTE, BTW.
Old 11-21-2010, 06:03 PM
dwalls56's Avatar
dwalls56
dwalls56 is offline
well unfortunatly i added a 6" suspension lift to the truck 2 weeks after i bought it, so my warranty is VOID. Do you all think i would be better off replacing the sensor on my own or taking it to the dealer anyways...?
Old 11-21-2010, 06:07 PM
george6488's Avatar
george6488
george6488 is offline
Take it to the dealer. The lift kit is unrelated to the problem you now have.
Old 11-21-2010, 07:01 PM
Jus2shy's Avatar
Jus2shy
Jus2shy is offline
Suspension and certain drive train component warranties may be void by your suspension, but a 6" lift has nothing to do with a throttle position sensor. I don't think they can void that portion of your warranty due to a lift. Just like george says, take it to the dealer, and I would also protest any reason they use to try and deny your TPS warranty.
Old 11-23-2010, 09:05 PM
RBacio's Avatar
RBacio
RBacio is offline
You're going to be pleasantly surprised when you go to the dealer and find that it is still covered by your warranty. I love it when that happens.
Larry1120
2004 - 2008 F150
07-01-2017 10:38 AM
cwilson7938
2015 - 2020 F150
06-08-2017 05:51 AM
Hunt77
2004 - 2008 F150
12-22-2016 10:32 AM
scottie54
2004 - 2008 F150
11-12-2016 09:36 AM
mccorpa
2009 - 2014 F150
04-21-2016 03:22 PM
Quick Reply: 2010 F150- P2135 DIAGNOSTIC CODE
