Best 3V Spark Plug
Best 3V Spark Plug
I have read and searched and found some answers, but now I can't find it by searching so here goes my first post. Did Motorcraft start welding there 2 piece plugs for the 3v to help the breaking problem? Which plug is the best replacement for the 3v 5.4 in a F250? (Brand and part # please)
I have replaced the plugs in my 2008 F250 at 92,000 miles and broke 1. Put high dollar Champion one piece in and now have intermitten miss more so when cold. I want to correct the miss with probably Motorcraft plugs, but want to know the latest design part number if there is such a thing. Any info will help.
Thanks,
Thanks,
Thanks for the response, but they are the two piece design. I read somewhere that the new design started in like September engines built and mine was almost exactly 1 month to the day of whatever that date was. I have ran Champions in racing engines in the past as well as NGK with no problems, but now I am getting a miss by the scanner on 5 and 7. (Number 6 broke by the way.) Used the Lisle tool to remove and it worked great. By the way is there a trick to seaching because I found more info on this forum by searching on Yahoo than using the seach here. Seems like the forum seach pulls up a lot of things that are not in the seach criteria. Found info on the E3 and Mororcraft SP-507 through Yahoo on this and other Ford forums. Same search here brought up way to much BS. Thanks again for responding.
I have seen people replace plugs as maintenance not having a miss. Put in champions in a newer ford engine and have a miss. They just dont work well with Fords. I have an 06 5.4 3V and I ran 127k miles on factory plugs before i had a miss. Removed the plugs and didnt break any. There are some tricks to gettin these plugs out with out breaking them, but can be time consuming. But i have done my fair share of pullin out broken ones. And i have also removed a couple of heads because other ppl tried to pull them out and hit the porcelain too hard....
I havent done any experimenting with different plugs in a 3V, so i cant really say of a good aftermarket plug.
Thanks I will be pulling the Champions and putting in the Motorcraft soon. I have also noticed a drop in fuel mileage and its not like the 5.4 in a F250 get great mileage anyway. I sorta thought that maybe winter blend fuel might have hit the area, but I am going to change the plugs and see if that helps.
dixie460
1983 - 2012 Ranger & B-Series
04-08-2017 07:58 PM
Resendiz
06-03-2016 05:58 PM
iirnited
3.8 & 4.2L V6
04-21-2009 11:37 AM
