Drop Spindles?
Old 02-28-2003, 03:30 AM
NarleyHarleyGuy's Avatar
NarleyHarleyGuy
NarleyHarleyGuy is offline
Drop Spindles?
I want to lower the front of my '66 and can only find drop beams or lowering coil springs.
Does anyone know if drop spindles can be bought anywhere? I can only find them for the newer Fords.
If I go with just lowering coils and drop it 3" will a front end alignment shop still be able to align my truck OK?
I've been told that the only way for a shop to align twin I-Beam suspenstion is to heat the beams up and bend them. Is this true?
Thanks,Patrick
Old 02-28-2003, 08:26 AM
William's Avatar
William
William is offline
Drop Spindles?
Beams are bent hydraulically with special tools. Find a shop that does this work without heat. Lowering the truck with dropped beams and coils will get you very low. If you need to get into the weeds consider a aftermarket cross member and air bags.
Old 02-28-2003, 11:52 AM
Mike G's Avatar
Mike G
Mike G is offline
Drop Spindles?
Seems to me that a set of drop spindles, if available, from a 1978 or earlier truck would all fit... I will have to agree that aligning the front if you use drop springs would be an issue and something would have to be done to the stock beams. Using the drop beams however will eliminate the issue, that is the whole reason for their existance. These are not the cars of the 90's where a tweak to the castor/camber or a shim here and there can make up for a cut in the springs.
Just my thoughts of course (not much room in the small processor for anything else...)
--MG
Old 02-28-2003, 06:20 PM
qtrmiler's Avatar
qtrmiler
qtrmiler is offline
Drop Spindles?
I bought drop beams for my '65. I would do it again! DJM makes a great kit. 3" in front, 4" in rear.
Old 02-08-2013, 02:03 PM
The Masked Rider's Avatar
The Masked Rider
The Masked Rider is offline
OK, here ya go. For anyone that wants to drop their ride. Different yrs are posted. I have NOT used this company, its only information passed along. Would I buy from them, sure, why not unless it was free. THis is only how one man feels about this product after beating it to death. One must make up their own mind.
I just got off the phone with a guy I've know for a while and this is what he uses. This guy burns a lot of track time (drags) and has slammed that front end down many times after the wheels have left the ground and has had NO problems with them bending. Spinle neck are strong and the springs take up most of the pounding after that - not the bars. He also admitted there are companies out there you may want to stay away from. He made NO mention of that except he didn't want to fall into that trap of slamming a company. NO future in it as he put it. Stated: "When first installed, the alignment was almost perfect on the left but the right had to be tweaked just slightly - most likely already out of alignment. He has a 3" drop all the way round. As for it not being 3" drop as advertised - false, it is. He said if the drop isn't as advertised, something else is worn out or wrong on the refit." He said the company is very willing to work with you on figuring out the problem. Hold on to your BUTT, it ain't cheap. Course what isn't.
There ya go, have fun surfing...
Ford | DJM Suspension | DJM Suspension
hogstop
01-09-2017 12:26 AM
fatheroftwo
16
12-09-2016 03:01 AM
Megatron1969
11-09-2010 12:44 AM
echobunny
19
07-12-2010 12:16 PM
SPRPRBGT
34
01-24-2007 02:09 PM
Quick Reply: Drop Spindles?
