Ignition switch wiring diagram/color coding
Old 11-16-2010, 06:45 PM
staysbroken's Avatar
staysbroken
staysbroken is offline
Anyone know where I could find a wiring diagram relating to the ignition switch?
When I bought my truck, the previous owner had rigged toggle switches and a push button in place of the ignition switch. So, I just snagged a complete switch and the wiring plug off a '76-ish F150 in a junkyard, and dropped it off with a locksmith to be rekeyed.
Old 11-16-2010, 06:50 PM
Nathan Plemons's Avatar
Nathan Plemons
Nathan Plemons is offline
Shoot me an e-mail and I'll send you the complete 1974 wiring diagrams. Should be the same switch.
Old 11-16-2010, 07:05 PM
staysbroken
Email sent, thanks!
Old 11-16-2010, 07:08 PM
Nathan Plemons
Should be on the way. Hope it helps.
Old 11-16-2010, 07:16 PM
steponit's Avatar
steponit
steponit is offline
The switch on the 78 is different than previous years
Old 11-16-2010, 07:25 PM
staysbroken
Yeah, I don't expect it to be completely plug and play, especially since my existing wiring is cut and spliced as much as it is already. I'll be doing a bit of testing with the multimeter to get everything working right
Old 11-16-2010, 07:29 PM
steponit's Avatar
steponit
steponit is offline
Old 11-16-2010, 09:11 PM
staysbroken
Thanks guys! Hopefully the locksmith will be done rekeying the thing early tomorrow so I can get to work!
...I cleaned up my under-hood wiring pretty well yesterday and today; tomorrow is time to tackle under the dash!
Old 11-17-2010, 08:36 AM
Nathan Plemons
I was working on getting my cluster to work and I moved something and I heard the unmistakable sound of something electrical arcing for just a split second. I got to looking around and there was as white wire behind my cluster with a stripped end connected directly to the starter solenoid terminal, otherwise connected to nothing. Glad I ripped that out before it burned the whole truck to the ground.
Old 11-17-2010, 02:22 PM
steponit's Avatar
steponit
steponit is offline
Especially since that Yellow 3-way connector is a keyed power source.
Old 11-18-2010, 08:49 AM
staysbroken
Well, apparently the switch I got was actually from a 78 truck, as the part number started with D8... All I had to do was to match up color to color, and everything works perfectly now! The color coding does match up in the diagrams you guys gave me, but there are several wires in the 78 that apparently were not in the earlier year models.
The locksmith charged me $40 to rekey the lock though, wasn't expecting it to be near that much!
Old 11-18-2010, 09:05 AM
Nathan Plemons
That that seems a little high, but hey, at least it's working!
Alaska1
Electrical Systems/Wiring
05-16-2017 12:22 PM
mountain dewd
02-07-2016 06:18 PM
martinbarrio
1978 - 1996 Big Bronco
11-07-2015 11:37 PM
Brown_Jonathan89
10-26-2012 02:07 PM
petty437
01-04-2007 05:36 PM
Quick Reply: Ignition switch wiring diagram/color coding
