Injector Wiring Harness $109.99
I tore my truck down this weekend and found that my injector wiring harness was all jacked up at the FICM connectors.
They were so brittle that the connector housings came apart in 3 pieces, one piece stuck in the FICM and had to be removed with some needle nose pliers.The pins and wires were exposed. I used a plastic epoxy to try to put it back together, but it turned out pretty crappy.
Needless to say my truck ran like crap when I put it back together. No codes but I had a blown FICM fuse and the truck still ran like crap when I replaced it.
So thinking that that harness is most likely the culprit I started searching for an injector harness and found a guy on ebay that has a pile of brand new harnesses for $109.99. I thought that was a pretty good deal and I know connectors break easily, so I figured I would let y'all know about it.
I don't know where this guy got them, and I hope that they are not stolen, but I'm not askin any questions.
Here's the links to his sales:
NEW 03-07 FORD 6.0 DIESEL INJECTOR HARNESS SAVE $300: eBay Motors (item 190451202876 end time Nov-29-10 19:09:01 PST)
NEW 03-07 FORD 6.0 DIESEL INJECTOR HARNESS SAVE $300 - eBay (item 170548207619 end time Dec-02-10 04:05:53 PST)
I would check with www.partsguyed.com who is a Sponsor here on FTE I just check his site for FICM Harness part # 3C3Z9D930AA and it's 70.87
I couldn't find it on his sight. I don't doubt he has it on there though. I guess it's not such a good deal then. Oh well, thanks for the heads up, I'll be sure to check his sight first from now on.
When you go to his page www.partsguyed.com scroll down to
Search by Part Number or Keyword put in part number 3C3Z-9D930-AA than select make FORD than Search
You can also send him a pm what you need. Give him Year; Model & VIN he will get back to you with info https://www.ford-trucks.com/forums/p...newpm&u=311089
I deal with Ed all the time..Great Guy
3C3Z9D930AA Jumper from 12B637 to fuel injectors. Engine Serial #'s 6030201 and after. NOTE: Prior 1/30/03, 9D930 not servicved separately, part of 12B637 engine harness. Clip for harness to fuel injector retention is part # W301222, Injector Harness, Navistar # 1843796C9*, FROM 1/30/03, 2003 ; 6.0 8 Cyl
2004
4C3Z9D930AA Fuel Injector jumper harness, from 12B637 to Fuel Injectors. NOTE: Clip for 9D930 harness retention to fuel injectors is part # W301222 After 12/01/03, Navistar # 1844137C9*, 2004 ; 6.0 8 Cyl, Ford 250 Series
2004
kevinwebster1
08-11-2011 04:03 PM
shephard199
15
12-02-2010 08:39 PM
3c3z9d930aa, 60, 60l, clips, diesel, f250, f350, ficm, ford, harness, harnesses, injector, powerstroke, specializing, wiring
