Restoration help
Restoration help
Hi, new guy here in need of some help. I picked up a 79 F250 recently and want to put some money in it getting it fixed up. I need to find someone who does welding near the Danbury area to replace a rear shock mount and leaf hanger and cross member in the bed.
It'll also need some leaks fixed in the rear diff, transfer case, valve covers and exhaust manifold. But I'd like to get the welding done first.
I don't think that it's in that bad condition, but there is definatley rust to deal with and flaking on parts of the frame.
If anyone has any suggestions on the best place to get some of this work done for the money I'd appreciate it. This is my first time tackling anything like this so I am not sure where to start and could really use the help. Thanks guys.
i dont even know where danbury is so i cant help you out there, butthe crossmember and spring hangers are all riveted to the frame. if you grind the heads off, you can pound the rivets out (or drill them out) and reassemble with your new parts and grade 8 bolts. if you dont feel comfortable doing it yourself, your local mechanic probably has done 100 of the broken shackle/hanger fixes because it was a problem from the 70's right through the 80's and 90's. they rot out badly on the rangers too.
welcome to the CT chapter
rattleNsmoke
Conventional (Bumper Pull) Towing; Travel Trailers & Pop-ups
10-10-2011 06:09 PM
Nickygunz
05-25-2011 01:32 AM
