1997-2006 Expedition & Navigator 1997 - 2002 and 2003 - 2006 Ford Expedition and Lincoln Navigator Discussion
2000 Expedition bypassing the auto-4x4 to make it 2x4?
Old 11-03-2010, 08:18 PM
ThatFordGuy's Avatar
ThatFordGuy
ThatFordGuy is offline
We have a 2000 ford expedition eddie bauer. Its 4x4 selectors have 4x4auto, 4x4hi, and 4x4low. The hull sensors keep acting up kicking it in and out of 4x4 even were just driving on pavement. We want to bypass those hull sensors or something so we can just strictly have it in 2x4 like regular package trucks like my uncles. Anybody know what im talking about or have any suggestions?
Old 11-03-2010, 08:34 PM
pdqford's Avatar
pdqford
pdqford is offline
Hull sensors?
What is a hull sensor?
Where is it?
And what do it do?
Old 11-03-2010, 11:46 PM
alloro's Avatar
alloro
alloro is offline
Received 4,196 Likes on 2,432 Posts
Remove the 30 amp fuse #104 from the under hood fuse box. It's okay to leave it out, you just won't have 4WD even if you turn the selector switch, unless of course you first put the fuse back in. Some have gone so far as to setup a switch on the dash to flip from inside the cabin.
Old 11-04-2010, 06:24 AM
orleec's Avatar
orleec
orleec is offline
For mpg improvement I suppose? What's the consensus on this, worth defeating the A4WD for a little mpg improvement, if any?
Old 11-04-2010, 07:06 AM
Big Greenie's Avatar
Big Greenie
Big Greenie is offline
Temporarily Deactivated
Instead of disabling the system, why not fix it?
BTW, it is not an Eddie Bauer option, all of the '99-01 Expy's used the A4wd as the default setting.
There is no mpg improvement to be had. Without major hardware changes pulling the fuse simply disables the 4wd engagement.
Old 11-04-2010, 08:40 AM
alloro's Avatar
alloro
alloro is offline
Because maybe for either time or financial reasons he is not able to fix it for the moment. Pulling the fuse will allow the truck to be driven until it can be fixed. My guess is that he's just going to need a set of 4 matched tires to solve the problem anyway...that or a wheel sensor.
Old 11-04-2010, 10:11 AM
Big Greenie
Well I sure am glad you can read minds
I was just asking the question.
Old 11-04-2010, 01:39 PM
alloro's Avatar
alloro
alloro is offline
I can't, it's just that he asked how to disable it, not how to fix it. I figured he has his reasons and it wasn't my place to question his motives...unlike some.
Old 11-04-2010, 05:27 PM
madsonp's Avatar
madsonp
madsonp is offline
Yep, I agree, if he has mismatched tires, that's probably the cause of his problem.
Old 02-14-2011, 10:38 PM
ThatFordGuy
we have all four of the same tires on it. turns out that the front and rear tires are supposed to have different tire pressures (door jam says so) supposed to run one set with 5lbs less pressure than the other. We adjusted that and now it does just fine. no more jumping in and out of 4x4.
Old 02-15-2011, 06:42 PM
madsonp's Avatar
madsonp
madsonp is offline
I've always run all my tires at the same pressure and I've never had any problems.
Old 02-15-2011, 07:44 PM
Junebug_'s Avatar
Junebug_
Junebug_ is offline
Fix it! :-)
theivan28
1999 to 2016 Super Duty
23
09-12-2016 03:49 PM
awatts18
13
05-26-2016 06:34 PM
ultraranger
General Automotive Discussion
13
05-20-2016 03:43 PM
carlhwv
Vehicles for Sale
04-09-2016 05:16 PM
coreyallan01
26
02-06-2016 06:01 PM
Quick Reply: 2000 Expedition bypassing the auto-4x4 to make it 2x4?
