fuel tank / vent valve
hey guys i need some help on 1993 ranger fuel tank ok first i know about the fuel pump but right next to it guess is a vent valve from what i read about for the first time ok here is my question is vent value needs to be connect to a hose? it's my first time removal the fuel tank off ford ranger that ya im ask so if anyone can help me out here would be great thank
If your about to drop the tank to work on, or change the fuel pump, it's said by those that have done it, that it's easier to disconnect the fuel filler hose, tail light wiring harness connector, remove the tailgate to make te bed lighter, then unbolt & slide the bed back to rest the front on the rear tires, the back portion on saw horses.
Then you can access the fuel pump without having to disconnect the fuel fller hose, drain & drop the tank, which is said to be a bigger pia.
Yup as has been said, there is a vacuum line at the tank that goes to the vapor recovery canister & those tank fumes are recovered & used to help the engine start & run easier when cold, so that hose needs to be hooked up & in good condition for the engine to run right, have lower emissions & prevent vapor recovery system trouble codes.
thanks for any help.
jonmammenga
01-10-2017 12:08 AM
brianm767
1983 - 2012 Ranger & B-Series
02-13-2016 08:30 PM
33homerdoodle
01-17-2016 04:00 PM
JSP2242
11-09-2010 06:40 PM
