Set dash clock 1985 F150-XL
Hi.
I had to swap out a steering column in my '85 F150XL. I disconnected the battery while doing the swap out, but now that everything is back in, I can't seem to figure out how to reset the dash clock. The clock is located at the top of the center dash section, has three buttons on the left side of the display. (Date, E-Time, Time) On the right of the display are two tiny buttons.
I've tried everything I can think of, but I can't get the display to change. Bummer! The clock has ALWAYS been set, and keeps good time. How do I get the display to update???
Thanks!
Thanks!
Great idea! I have a feeling the little buttons on the right don't work any longer.
Just for the record, what would be the combination of buttons needed for the time setting, and for the date setting? (just in case they work, and someone else searching for the same info might find it useful...)
I was afraid of that. Neither of the small buttons work any longer. I pulled the battery cable right at noon today, so at least now I have the right time.
I'll try Beetle's suggestion on the contacts when I get a chance.
Thanks all!!
Anafiel
I just checked the 1985 Owners manual about the factory option digital clock and hw to reset it.
HERE GOES:
IGNITION or "ACC" Must Be Switched On!!!!!!!!!!
3 large buttons on the left side of the display from left to right
Date = E-Time = Time
2 Small round buttons on right side of display, from left to right
L/Set (button1)= R/Set (button2)
To Set the Time:
Depress the "Time" button and either "button1" or "button2"
"button1" will advance the hour, an "A" will appear for AM & "P" for PM
"button 2" will advance minutes
To Set Date:
Depress "Date" button and hold down "button 1" or "button 2"
"button1" will advance the month
"button 2" will advance the day
E-Time - Elapsed Time
Depress "E-Time" button to go to the E-Time Mode
"button 1" used to zero timer
"button 2" is used to start and stop timer
Display will flash when timer is stopped
Hope this helps
HERE GOES:
To Set the Time:
To Set Date:
Hope this helps
UPDATE:
All fixed! I took the clock out to clean the contacts as suggested, but found the real problem right away.
Seems ford was running short on little screws the day they assembled the clock. There are six screws that hold the PCB in the casing. Two in the center, and the four corners. On mine, they only used two screws on the opposing corners, so the screw post on the end with the little setting buttons broke off. What was happening was when you push the setting button, it was actually bending the whole PCB out and away.
I super glued the post back, and found screws for the posts that didn't have one, and now the buttons actuate the switches correctly. All the functions of the clock operate perfectly now.
Thanks for all your help guys. Your suggestions led me in the right direction!!!
Anafiel
Anafiel
I know this is an old thread but I just wanted to bring it back to say thanks. My clock buttons have never worked good, today I took it apart and sanded the contacts like it said here. I figured I have nothing to loose. Not even ten minutes later it was back in and probably hasn't worked this good since new!
TallPaul
10-02-2004 10:29 PM
