HIGH IDLE ???
Old 10-24-2010, 09:41 AM
crowex's Avatar
crowex
crowex is offline
HIGH IDLE ???
Was reading the owners manual on the high idle and it says you have to have the E - brake applied for it to come on automaticaly. Bad news for us people who live in the north. You just cant afford to take a chance at 35 below an dend up with afrozen E- brake cable!!! Hoping someone might know how to bypass this. By the way I have now upliffter switches.
Old 10-24-2010, 02:52 PM
kper05's Avatar
kper05
kper05 is offline
SEIC has always required the e-brake since 2005 at least.
SVE bulletin Q-108 for 2005 confirms the parking brake is required.
I don't know what model you owned previously so that could have an impact and I don't know how it worked previously to MY2005.
The only changes I'm aware of is with the 6.0, owners could leave the SEIC switch on and regulate high idle using the e-brake. With the 6.4 and 6.7, leaving the SEIC switch on will not allow the DPF to regen (so I've read) so now it's a two step process.
Old 10-24-2010, 04:52 PM
crowex's Avatar
crowex
crowex is offline
I had 2005 but was an early model. Thanks that helps!! I will just have use the 1 click method to make it work.
Old 10-24-2010, 05:21 PM
ruschejj's Avatar
ruschejj
ruschejj is offline
You know, I've been racking my brain on this. I am 99% sure that the cold weather strategy for the elevated idle will work even if the parking brake is not engaged. I had a 6.4 ('08) and I swear that during cold weather the PCM would elevate the idle regardless of parking brake position, as long as the truck was in "P" for park on the gear selector.
Now, if you wire a 12V source to the PTO or SEIC wire under the dash, you will need the parking brake engaged.
My new 6.7 has not experienced cold weather yet so I cannot confirm on these new trucks but I would bet it's the same as the 6.4.
Old 10-24-2010, 10:13 PM
kper05's Avatar
kper05
kper05 is offline
By high idle I assumed SEIC but the cold weather (auto) idle (crowex did say auto, I missed that) may not. I guess we'll see. Someone up north may have experienced this already.
Old 10-28-2010, 03:12 PM
mvedepo's Avatar
mvedepo
mvedepo is offline
If I just want to hook up SEIC is it just a matter of wiring the SEIC pass through to the Upfitter switch I want through a resistor? Or is there more too it?
Old 10-28-2010, 04:24 PM
mvedepo's Avatar
mvedepo
mvedepo is offline
Here is where I am at. I hooked up the wires below with a 22K 1/2 Watt resistor with no luck.
Ideas? Is the yellow and green wire I am hooking up to the correct one for SEIC?
Thanks!
Old 10-28-2010, 04:35 PM
ruschejj's Avatar
ruschejj
ruschejj is offline
All the info you need is right here:
https://www.fleet.ford.com/truckbbas...tml/Q180-A.pdf
Specifically, there is a chart "B" that gives you resistor values for target RPM.
Old 10-28-2010, 04:44 PM
mvedepo's Avatar
mvedepo
mvedepo is offline
Yes I saw that and printed it out. The resistor I am wanting to use is 20K but its not available. I can only find a 22K. The question I have is am I using the correct wires? The SEIC pdf that I read refers to a bundle of 4 wires which includes the SEIC and PTO wires. I can't find such a bundle. Just the the pigtail of a bunch of wires. I also read that the SEIC wire was the YELLOW/GREEN wire.
I found one but I am not sure that its the correct one.
Old 10-28-2010, 04:47 PM
ruschejj's Avatar
ruschejj
ruschejj is offline
Well, I wish I could help. The only thing I could offer to the thread was remembering where that .pdf file was. I have not done the mod myself so I'm not really any help to ya. There should be more info floating around, I remember somebody going into pretty good detail on this.
Old 10-28-2010, 10:28 PM
mvedepo's Avatar
mvedepo
mvedepo is offline
PROBLEM SOLVED!!!!!!!!!!!!!!
Need to connect the YELLOW/GREEN DIRECTLY TO THE AUX SWITCH
Then connect PTO_REF (WHITE WIRE WITH BROWN STRIPE) to PTO_RPM (GREEN WIRE) WITH A RESISTOR BETWEEN THEM. Works like a charm!!!
I was using the WRONG (BROWN/WHITE) WIRE!!
NOTE!!!!!
There is a BROWN WIRE WITH WHITE STRIPE.....NOT THE RIGHT WIRE!
USE THE WHITE WIRE WITH BROWN STRIPE!!!!!!
Old 10-28-2010, 10:47 PM
mvedepo's Avatar
mvedepo
mvedepo is offline
THIS ONE WORKS!!!!!
Old 10-28-2010, 10:49 PM
RickSo's Avatar
RickSo
RickSo is offline
Need to connect the GREEN AND YELLOW DIRECTLY TO THE AUX SWITCH
NOTE!!!!!
INPUT (VPWR)
PTO
REQUEST1
PCM Pin C1232B-6 Circuit No. CE912 Wire Color: Yellow / Green
• Applying vehicle battery voltage to this wire begins SEIC process.
• Signals TorqShift™ transmission to enter SEIC strategy.
• Verifies safety enablers.
• Turns off OBD and other emission-related monitoring.
• Elevates engine speed to target found at PTO-RPM circuit.
• Invokes the PTO relay circuit when safety enablers are met.
• Looks for the target engine speed requested at the PTO_RPM circuit using a resistor or POT.
That's great!! Just want to make sure your two posts above should say "Yellow/Green". The picture above show's "Yellow/Green" wire correct?
Rick
Old 10-28-2010, 10:51 PM
mvedepo's Avatar
mvedepo
mvedepo is offline
Fixed. Thanks! :-)
Old 10-28-2010, 11:01 PM
RickSo's Avatar
RickSo
RickSo is offline
Thanks very much for posting that picture it will help many people out with the high idle.
Rick
Quick Reply: HIGH IDLE ???
