61 Unibody Clutch
61 Unibody Clutch
I've been digging around here with the search tool and on the net at the various vendors, but haven't found what I'm looking for so...
My truck is a '61 F-250 (VIN: F25JK170***)with an I-6 (C3AE-6015 AC cast on the side) and a four speed T-98. It's been an occasional driver/stuff getter/trailer puller with a slipping clutch for a few years and I figured it was high time I addressed the clutch. I just needed to get it back up and running since this truck will likely get a whole new drive train before it goes through another clutch.
After doing some research, I went with the Rock Auto "BRUTE POWER / PERFECTION CLUTCH Part # 92652" kit offering. I hadn't taken mine apart yet when I ordered the kit, but figured it was an 11" unit and went with it. I went in expecting to replace the pilot bearing, release bearing, pressure plate, and friction disc and resurface the flywheel...
Then, I pulled my clutch apart yesterday...
The release bearing was so bad that it destroyed the release lever, release bearing hub, and the pressure plate drive lug fingers. I also discovered that the release lever retracting spring was missing. So it's back to the drawing board to find the release lever, release bearing hub, and the release lever retracting spring.
To add insult to injury, the inner "spline area" of the replacement friction plate is about 0.31" deeper than on the one I took off. I'm hoping it doesn't matter.
The only part I've found so far is a release bearing/bearing hub assembly from Rock Auto. I already have a bearing as part of the kit I purchased, so another bearing would be a little wasteful. Any advice on where to find the release lever, release bearing hub (by itself), and the release lever retracting spring would be appreciated.
Thanks,
P
Thanks,
P
B8C7515A .. Clutch Release Lever (aka Clutch Fork) / Obsolete
Fits: 1957/64 F100/950.
GOODE MOTOR CO. in Burley ID has 1 = 800-535-7278.
BARRY MOTOR CO. in Danbury IA has 1 = 712-883-2421.
JONES WEST FORD in Reno NV has 7 = 800-323-2223.
GREEN SALES CO. in Cincinnati OH has 29 = 800-543-4959.
B3TZ7561A .. T/O Bearing Hub / Obsolete
Fits: 1953/63 F100/700 / 1964 F100/350.
ARTESIA FORD in Artesia NM has 1 = 575-746-3578.
PIONEER FORD in Groton SD has 1 = 605-397-2311.
GRIESEL MOTOR CO in Okarche OK has 2 = 405-263-7242.
GREEN SALES CO. has 3.
KINSEL L/M in Beaumont TX has 6 = 800-816-2894.
C1TT7523E .. Clutch Release Spring / Obsolete
Fits: 1961/65 F100/250 2WD / 1966 F100/250 2WD before serial number 830,001.
GREEN SALES CO. has 8.
Look at the post again, there is no need to call salvage yards. I wanted to see where you lived before editing in the sources.
This is why I typed brb (be right back), watch this post.
Call around for the best prices. The dealers are usually cheaper than obsolete parts vendor Green Sales Co., cuz they are STUCK with the parts.
myakkacracka
13
06-16-2016 11:33 AM
NMFirstF2504X4
07-14-2015 07:40 AM
Flintknapper
17
02-18-2015 08:00 PM
myakkacracka
03-17-2014 07:35 AM
redman84
17
05-29-2013 12:38 PM
