92 f250 rear main seal
Yes, care must be taken when removing old seal to not damage shaft or you will be back at square one in short order. Re-installing seals is a operation in patience, surface cleaning prep, properly driving them in (flat- proper tool) and seating at correct depth.......plenty of prof. mechanics fail at this because they are in a hurry, do it right and you wont have to do it again.
-Remove trans
-Remove flywheel/flexplate
Theres the seal, around the crank. I normally remove them using 2 self tapping screws inserted into the seal 180* apart. But be VERY careful when installing the screws to NOT touch the crank, or you WILL scratch it and it will NEVER seal again. Grab one screw w/ a vice grip, and pull it out, you may need to pry it w/ a prybar, sometimes on the newer trucks you cant just pull it out.
-To install new seal, you will need a seal driver to get it in straight and all the way in. I found a short piece of PVC pipe the same diameter as the seal, w/ one end capped, works well as a home made seal driver.
Tips:
-Make sure to lightly oil the seal lip before sliding it over the crank, helps prevent tearing of the seal in the short time there is no oil on the other side of it at first start up
-also i recommend using permatex ultra black around the OUTSIDE diameter of the seal, ive found if you just install them as is you have a 50-50% chance of oil leaking around the outside diameter after installation.
Hope this helps!
Tips:
Hope this helps!
Also, sometimes the seal will wear a groove in the crankshaft, which may cause difficulties getting a leak proof seal, but you can get a repair sleeve from an auto parts store, which fits over the crankshaft. May want to check for that too, and maybe replace the front pump seal on your trans while it's out, if it's an automatic.
waylen89
03-21-2016 02:49 AM
teardropty
08-04-2012 03:28 PM
Fullsircle
09-15-2011 03:51 AM
Mr Man
04-18-2002 07:07 PM
