I have a 78 Ford F600 with the 361.
Has a Holley carb on it. The tag reads Motorcraft D8TE AHA 7L4.
What model Holley is this. I need a rebuild kit.
Thanks
NAPA part # is 25819 for rebuild kit , it is not a Holley carb ! it is a motorcraft carb , ford copied the Holley some parts may interchange though ! with all those big trucks NAPA is the best place to get parts
Look on the air horn for a stamped "List" number. That's the number you need to order Holley kits.
I've lost many favorites links with computer problems but I couldn't find a Holly kit number once (GMC C7000). Went to Holley website, got tech assistance 800# called for kit number, ordered kit from summit racing. It's bazzar what you can order from Summit racing with a good part number. They may not have a clue what it is but they can order it.
Thanks
I have a high mileage 1972 F700 cabover with a very tired carb. The engine is a 361. Will a (replacement) Holley 2- barrel series 2300 fit on it, and if so, would a 350 or 500 cfm be better?
