engine accelerating on its own
Old 10-12-2010, 11:58 PM
cybercytes's Avatar
cybercytes
cybercytes is offline
'93 E150, 5ltr/302ci, FI, auto/OD
accelerates on its own, and will hold 60 MPH in OD
I can be sitting at a light, then the engine RPMs will greatly increase by itself
sometimes I can shut the engine off and restart...then it will go back to low idle
however, after a short time, the RPMs will start increasing again
occasionally the check-engine lite will come on for a few minutes, then reset
no customary reason found for this
the steering wheel air bag "clock spring" has needed replacing, so horn and cruise are not working
could this be the issue that's creating the acceleration?
or is it related to the fuel-injector system?
or something completely different?
your thoughts greatly appreciated
Old 10-13-2010, 12:07 PM
katula's Avatar
katula
katula is offline
a problem with the wiring in the steering column could be causing your problem. Since you know that there is a problem with the air bag, I would start there. Be careful around the air bag though......those things will reach out and slap ya....
Old 10-13-2010, 12:25 PM
cybercytes's Avatar
cybercytes
Agreed..always disconnect battery first.
Old 10-16-2010, 08:30 PM
firepop5's Avatar
firepop5
firepop5 is offline
Maybe something to do with cruise control wiring in steering wheel. Try disconnecting power to cruise control unit and see if problem still happens
ten.mile
05-16-2020 04:34 PM
Xcursion88
1999 to 2016 Super Duty
06-07-2016 05:47 PM
zapola6
Modular V10 (6.8l)
10-11-2015 07:54 AM
BigGreen7.3swap
13
09-28-2014 09:21 PM
JohnOsky
07-27-2010 06:32 PM
Quick Reply: engine accelerating on its own
