Explorer, Sport Trac, Mountaineer & Aviator 1991-1994, 1995-2001, 2002-2005, 2006-2010 Ford Explorer
2004 Explorer Transmission Question
Old 10-11-2010, 01:47 PM
ranstl's Avatar
ranstl
ranstl is offline
I have a 2004 Explorer XLT with the 4.0L and auto trans. Vehicle is 4wd. Mileage is 39k.
Had the trans serviced about 300 miles ago. Took a long (mostly highway) drive this weekend and had quite a bit of white/grey smoke coming from underneath about 30 minutes into it. A quick look revealed what I thought was a leak. Took it back to the repair shop that did the work this morning and he advised there is an overflow tube on these and it is common for this to happen on these vehicles after service. Has anyone else heard of this (the overflow tube, sure, but the spewing fluid has me concerned a little)? Does it really take a few miles for the fluid to "equalize" as he put it?
He also mentioned that he thought the front seal on the torque converter might have been bad (altho he ruled that out). He said that is a common problems on these vehicles, due to overheating the transmission. Is this really a common problem? I do tow occassionally with this vehicle (~3500 # boat, ~1500 # atv trailer/bike/gear) and I do have the tow package with the class 3 hitch. Should I be concerned.
Any input is appreciated.
Old 10-11-2010, 08:48 PM
jk080's Avatar
jk080
jk080 is offline
Transmission Rebuilder
No its not a common problem, but its also no problem at all. What happens is when the transmission is refilled from the service too much fluid is added because its cold and when the fluid gets hot and expands the extra is pushed out the vent tube. This is why you should check the fluid level when hot (operating temp). This can happen with any transmission, not just your type of vehicle.
What he should have done is fill it then drive it to get it hot and then drain the extra out.
Having too much fluid cannot hurt the transmission it just may leak from the vent.
Old 10-12-2010, 07:48 AM
ranstl's Avatar
ranstl
ranstl is offline
thanks for the explanation. i feel a little better now!
nice super duty, btw!
BigMESA
10-22-2016 08:25 PM
F250_6.7
2004 - 2008 F150
08-14-2016 07:52 PM
brychar
6.4L Power Stroke Diesel
56
07-16-2016 12:58 AM
GreenMM
43
04-21-2016 09:15 AM
Hurst89
2009 - 2014 F150
77
04-11-2016 04:30 PM
Quick Reply: 2004 Explorer Transmission Question
