before i give up i want your opinion....
Old 03-18-2012, 07:12 PM
matowns21's Avatar
matowns21
matowns21 is offline
Do I need to put the #8 injector in? What about the other glow plugs? And lastly how will I clean out the cylinders?
  #137
Old 03-18-2012, 08:02 PM
427 fordman's Avatar
427 fordman
427 fordman is offline
You only pulled one injector right? I used a syringe to suck it out. You can leave the other glow plugs out and put the injector in. As long as that broke glow plug isn't in the same cylinder you should be able to pull fuse 22 and just crank away even if you cant get the oil out of that cylinder. It will blow out the glow plug hole.
  #138
Old 03-21-2012, 10:12 PM
matowns21's Avatar
matowns21
I pulled all 8 injectors and replaced the orings. All but #8 are back in. I think I am going to pull the head so I can get the glow plug out and visually inspect the #8 cylinder for issues. Atleast that is what I'm telling myself.... Is there a write up on this and can I reuse the head bolts?
  #139
Old 03-21-2012, 10:32 PM
fordpride's Avatar
fordpride
fordpride is offline
I'm not sure on a write up but you'll have to buy new head bolts
  #140
Old 03-22-2012, 06:04 AM
427 fordman
Just checking Mike, does a guy "have" to replace the head bolts? I'm not sure, that is why I ask. I've built many engines with used head bolts with no issues, but none have had quite this high of compression either.
If you are gonna pull the head, make sure you have help or a cherry picker would be best. They are real heavy. I don't have a writeup either, but pull the injectors back out first so you don't damage them.
  #141
Old 03-22-2012, 07:29 AM
fordpride's Avatar
fordpride
I ve reused em before too on small blocks. The bolts on these engines or one time use. They've been stretched out. In normal driving I'd think it would be ok but after you start boosting on it is where I think the problem would come in
  #142
Old 07-21-2012, 11:30 PM
matowns21's Avatar
matowns21
Alright upon further inspection I have 2 big chips in the top of my piston #8 and I do have scars on the cylinder.... I know the scars on the cylinder are rings, but what would cause the chips? It also looks like cavitation on there.... What do I need to do now?
  #143
Old 07-21-2012, 11:37 PM
1dieselman's Avatar
1dieselman
1dieselman is offline
Rings shouldn't have scarred the cylinder walls unless they are broken. Maybe a broken glow plug chipped the piston. Got a picture of it?
  #144
Old 07-21-2012, 11:42 PM
matowns21's Avatar
matowns21
I don't have a photo bucket account and my phone is about dead. Do you have an email I can send them to?
  #145
Old 07-21-2012, 11:49 PM
matowns21's Avatar
matowns21
Is there another way I can download them without photobucket?
  #146
Old 07-22-2012, 12:37 AM
Lead Head's Avatar
Lead Head
Lead Head is offline
imgur.com
tinypic.com
Make a free g-mail account and send the pictures to it?
  #147
Old 07-22-2012, 12:57 AM
matowns21's Avatar
matowns21
  #148
Old 07-22-2012, 01:00 AM
fl_mudlife's Avatar
fl_mudlife
fl_mudlife is offline
If it has a turbo check the turbo thats what was going on in our truck
  #149
matowns21's Avatar
matowns21
  #150
Old 07-22-2012, 01:01 AM
matowns21's Avatar
matowns21
Quick Reply: before i give up i want your opinion....
