98 F150 Intake Manifold Runner Control valve problem
My 1998 F150 4.2L V6 145K miles has developed a stuck open Intake Manifold Runner Control Valve OBD code 1537. Has been suggested by mechnic who attempted to conduct annual inspection that it is likely gummed up with cabon based on their experience. Looking for the does and don't of repair/replacement of the IMRC from those who have done this before. Thanks in advance for any and all helpful replies to this post
Regards kbgrn150 <!--IBF.ATTACHMENT_50615--> <!-- THE POST --> <!-- / message --> |
I remembered a thread from several years ago and dug it up. Maybe some help...
https://www.ford-trucks.com/forums/5...-acuators.html Try using the search feature on the top task bar, searching for your code or "IMRC" or "runner control". There is some info there, just nothing recent as the IMRC setup has not been used for several years now. Hope you get is squared away. |
hi, if it is the vacuum type check the pipe work for leaks and check that the lever arms have not come off the activators. if not sure suck on the rubber pipe and you will hear the flaps open and close all with the engine turned off. hope this helps bokker.
Originally Posted by bokker
(Post 9298312)
same problem with 4.2l
Originally Posted by kbgrn150
(Post 9273089)
Regards kbgrn150 <!--IBF.ATTACHMENT_50615--> <!-- THE POST --> <!-- / message --> The DOD |
