A complete Wiring Harness for a 74 up to 79 f250 not been spliced or chopped on
I'm looking for a steering shaft and tilt column for a77 f150 4x4 postal code R4K1C1 yes that's canada. Lol. Thanks
Lol also wanting anything smog/emissions for the 351M
I am looking for the rear interior trim and seat latch for my 78 super cab.
I need the brake booster mounting bracket and linkage.
Thanks! |
It looks like I have to be a member for 10 days and make 5 posts before I can get whatever you're sending me in reply. Unfortunately I will probably have the parts by then. I'm not going to wait around for this site to consider me worthy to buy parts from it. Again, my email is zillsm@yahoo.com it you want to contact me. I really don't get this. Just be aware that whatever message you send me through this site, I'm not getting it.
i need headlight mounts and buckets for 73-77. do you have and how much?
I need a front cross member ( welded on one) for 75 -79 f100 or f150 4x4 or 78-79 bronco
Im in need of dash vents if u happen to have any.
I need blue door panels for a 1978 f250 custom. My address is 5836 Bagley Ave. Apt. C 29 palms CA 92277.
I need a set of 2 blue door panels for 1978 f250. My address is 5836 Bagley Ave. Apt. C 92277. Thank you.
Looking for windshield and a 77 2wd power steering- steering gear box
Need burgandy door panals but will take anything what do the pace truck look like I have a79" f250 custom explorer will paint or cover them to match 99205 thanks steve
Hello,
Im looking for the fron sway bar brackets. The brackets that go attached to the front of the radius arm / i beam. My zip is 77040. Thank you |
I have no perfect door panels now.
Manfred-I have the steering box.What's your zip for shipping?.Windshields are sold. |
Originally Posted by 351coupe
(Post 14132928)
Do you have one of the factory Ford AM/FM radios?
Originally Posted by scarey1
(Post 11795687)
Do you know where I could locate that piece? i have tried to make one ( looks fair, not great) thanks,it must be the hardest part to find like unubtainum.......:-X19
the doors do you still have and need a bed i have a 1979 long bed f150 4x4
Parts to convert ac truck to non ac... manual heater.. controls.. manual kick panel vents
96003 Thank you notmeofficer@gmail.com |
I am looking for a steering column for a standard floor shift tranny in good condition. I need the fan shroud for the F-250 radiator and the bolts for the hood. 39183
Would you happen to have a 351m bell housing for a T-18? Thanks!
Do you have frame motor mounts towers for a 351m/400 in a 4x4?
Do you have any SB Flareside bed parts? I need the tail light brackets and the side steps for a 78 F150.
Checking to see if you might have any of the support rods that bolt on the bottom of the bed and run down to the bottom edges of the fenders?
Do you have a auto steering column and power steering gear box for a 77 F250 4x4 lowboy?
parts
I am looking for the factory "cups" that mount to a 460 block for the 73-79 trucks. I have towers and rubber isolators, but need the top pieces of the motor mount setup.
Looking for a Motorcraft 2150 2v carburetor to go on my 2wd 77 f150 351m c-6.
Shipping to 98405 |
parts
Do you have a working 77 am/fm radio?
Looking for door panels. 78 year. XLT, Ranger,Lariat or plain jane. Doesnt matter. Shipped to 32405. Thanks in advance.
Allen |
Looking for fan shroud shipped to 44060
I'm looking for 1979 lariat front, and rear door pannels816332 seven two five four
Looking for drivers side sun visor, Canada N2Z 2P6
Looking for the "F100" emblem for a 73, drivers side with the clips that hold it in place, shipped to 98685.
Thanks, Tom |
do you have door panels seat and dash pad in brown truck is a 78 shipped to 47355 thanks
Where in CT?
Looking for 300i6 engine perches for 1979 f150 4wd, thank you
(Post 11780558)
I have LOTS of 73-79 truck and 78-79 Bronco parts.I've been hoarding parts for too long,and some stuff has to go.A few trucks Ive stripped are:'78 Broncos,79 Supercab,78 F250 4x4,79 F350 4x4,75 F250 4x4(california,rust-free),78 F-150 shortbed 4x4,an Indy Pace Truck and more.If you need parts...chances are decent that I have it.
Ive tried to make some kind of a list. Body/interior/trim: Pair of Rust Free Doors(California Truck) (2)Pair Rust Free Fenders (2) 73-77 Grille Shells(1 mint-painted orange) (3) 78-79 Grille shells 73-75 grille inserts(not perfect,not bad) 76-77 grille inserts(painted black) 78-79 grille inserts(black,argent and chrome) Tailgate trim(all styles and colors I believe) Misc body stainless trim(no 8' bed trim,sorry) Door panels(black,brown,blue,tan,pace truck,xlt and lariat) Dash bezels Dash chrome trim-metal Visors A/C dash,compressors,etc Brown Lariat headliner Mechanical: 78-79 Dana 60 Kingpin,High-pinion Front Axle w/354s 9" rears w/350s NP435 for highboy or 2wd 4x4 C6 for np205 4x4 C6 for np203 Intermediate housings for C6 and NP435/T-18/19 to N205 Driveshafts(too many to list) 351m/400 flexplates and flywheels 360/390 flywheel(resurfaced) 351m/400 belllhousings 360/390 bellhousing 351m/400 rear sump 4x4 oil pan 360/390 rear sump 4x4 oil pan Just about any 351m/400 part Lots of 360/390 parts Steering/suspension/chassis: 4" lift coils (F150,Bronco) Rear springs/hangers steering boxes steering shafts frame crossmembers Dana 60 front U-Bolt perches F350 4x4 overload leafs Factory rear blocks Engine mount frame towers Quad shock brackets F250 Highboy 6" suspension lift Thats a short list...Im tired of typing.If you dont see what you need,just ask. YES..I WILL SHIP PARTS.IF YOU REQUEST A PART,GIVE ME YOUR ZIPCODE AND ILL GIVE YOU A PRICE INCLUDING SHIPPING.FREIGHT QUOTES FOR LARGER PARTS ARE BUYERS RESPONSIBILITY. |
Have a stock air cleaner -- '77 with a 460-4v?
Do you have a set of frame to engine perches for a 77 highboy? Would be to zip: 99645, thanks.
