contact info
can you give me a call? 978-766-4417
Parts Needed
Hi - I am looking for the following parts for a 79 f250 4 x 4 truck. Please email your prices to jdvorscak@rcn.com. I am looking for the following:
steering shaft with coupler and u joints between the steering box and steering wheel shaft. Need a good tight one. Rear spring hangers Rear spring mounting plates for the top of the springs center frame cross member - the one the two emergency brake cables mount to Thank you for your time. |
Parts Needed - Follow Up
PS please quote shipping prices to 18067. Thank you!
351 Block plate manual
im in need of a 351block plate for a manual Bellhousing.thanks dave lafermedavidm@aol.com
T18 bell housing for 460??
429/460 motor perches shipped to 44039
hello I was wondering if you a have bell housing for 460 ford with t-18 trans
Hi, I am searching for a sway bar end link for my 1979 F250 4WD 4spd 400 - driver's side...@ 72631. Or if anyone has info to help locate...appreciated . Thank You!
price for 73-79 f150 78/79 bronco 4x4 power steering box shipped to 91942
I need the rod that connects the steering wheel to thetransmission selector . The long slotted alternator bracket that youmake your belt tension adjustments on. I also need the c-6 inspection coverthat goes on the front of the transmission. |
Any 12" flywheels for the 400?
BigBruce-Should have everything....whats your zip?
Originally Posted by Bigbruce
(Post 13409377)
Originally Posted by joerickson
(Post 13413528)
Need rh lower front fender racetrack trim and drivers side black door panel
Hi,
Need rh lower front fender racetrack trim and drivers side black door panel. Can you let me know how much shipped to 95249? Thanks! Matt |
Would you happen to have a working factory fuel sender for a rear 19 gal tank?
whats the difference between a np205 and np203 transfer case? I need a c6 transmission for a 79 F150 Ranger XLT with a 400, but don't know the transfer case number. Would one of the transmissions you have work for me??
a np 203 is a full time transfer case and is chain driven. The NP205 is a part time transfer case and is gear driven
Thanks for the clarification lisagoud. I would need the np205 if it is indeed for sale.
Looking for an FE rear sump oil pan, pickup, dipstick and dipstick tube. How much shipped to 52537 ZIP code if you have it all.
Thanks, SPark |
Do you have 302/351 or 460 engine perches?
bell housing for an NP435 to a 300 I6?
Samsn-I have one.
If the bed is junk, I'd be interested in buying the fuel door area to convert mine to a dual tank truck. Need the fuel door, the plastic, and the small section of the bed.
How much do you want for the steering box and wondering if you have tie rods as well.
Looking for a painted fuel cap for 1975 F350. Paint code is W. Which is a darker shade of green. zip 83523
Zip code is 91104...
1979 f250 4x4 6.6 Im interested in black door panels, or any color in good shape, including the arm rest and pull cup thing. Also, dash bezel, black if possible. I have radio and a/c... 4x4 hubs, not sure of my specs Steering gears- power Please price to ship it all separate, thanks |
In search of 1/2 ton quad shock brackets
Originally Posted by 351coupe
(Post 11780558)
I have LOTS of 73-79 truck and 78-79 Bronco parts.I've been hoarding parts for too long,and some stuff has to go.A few trucks Ive stripped are:'78 Broncos,79 Supercab,78 F250 4x4,79 F350 4x4,75 F250 4x4(california,rust-free),78 F-150 shortbed 4x4,an Indy Pace Truck and more.If you need parts...chances are decent that I have it.
ISO the quad brakets for a half ton 4x4.My zip code is 37149,Thanks. Ive tried to make some kind of a list. I would appreciate your time to look for me. Body/interior/trim: Pair of Rust Free Doors(California Truck) (2)Pair Rust Free Fenders (2) 73-77 Grille Shells(1 mint-painted orange) (3) 78-79 Grille shells 73-75 grille inserts(not perfect,not bad)wgonrigi n ipo pij pij pij pij pij pijiph p 76-77 grille inserts(painted black) 78-79 grille inserts(black,argent and chrome) Tailgate trim(all styles and colors I believe) Misc body stainless trim(no 8' bed trim,sorry) Door panels(black,brown,blue,tan,pace truck,xlt and lariat) Dash bezels Dash chrome trim-metal Visors A/C dash,compressors,etc Brown Lariat headliner Mechanical: 78-79 Dana 60 Kingpin,High-pinion Front Axle w/354s 9" rears w/350s NP435 for highboy or 2wd 4x4 C6 for np205 4x4 C6 for np203 Intermediate housings for C6 and NP435/T-18/19 to N205 Driveshafts(too many to list) 351m/400 flexplates and flywheels 360/390 flywheel(resurfaced) 351m/400 belllhousings 360/390 bellhousing 351m/400 rear sump 4x4 oil pan 360/390 rear sump 4x4 oil pan Just about any 351m/400 part Lots of 360/390 parts Steering/suspension/chassis: 4" lift coils (F150,Bronco) Rear springs/hangers steering boxes steering shafts frame crossmembers Dana 60 front U-Bolt perches F350 4x4 overload leafs Factory rear blocks Engine mount frame towers Quad shock brackets F250 Highboy 6" suspension lift Thats a short list...Im tired of typing.If you dont see what you need,just ask. YES..I WILL SHIP PARTS.IF YOU REQUEST A PART,GIVE ME YOUR ZIPCODE AND ILL GIVE YOU A PRICE INCLUDING SHIPPING.FREIGHT QUOTES FOR LARGER PARTS ARE BUYERS RESPONSIBILITY. |
sorry didn't follow the rules,
Bell housing for an NP435 that bolt up to a 300/I6 zip:62966 Thanks |
4 white OEM wagon wheels?
How about the bracket that mounts between the firewall and brake booster for a 79? Not the linkage style.
If you have one, PM me a price shipped to 55944. Thanks |
1973 OR 1974 F100 FRONT SPINDLES AND DUST SHIELDS. ZIP 920664
Looking for tailgate trim panel set... pictures with price to email taco121@msn.com shipped to zip 77075 thank you
hello I am looking for rear bumper brackets for 77-79 flareside. They are the high type where the tag is mounted to the rear cross sill not the left tail lamp. OE number is d7tz 17787 a 17788 a. e2 each . They are mirrow image of each other. Stock narrow type bumper.Thanks
I am in need of a rear sump 351M oil pick up tube to 33572 Thanks
I get the feeling this thread is more of a dumping ground since the OP has not responded in a very long time, but, since I am prevented from starting my own thread for having "fewer than 5 posts" even though I have more than that, I'll throw my own request into the pot!
Need factory black mirrors for my '79 Indy truck. The mirror glass itself isn't important, but the plastic housing and metal mount are. These were standard on Freewheeling trucks and Broncos as well as the Indy trucks, and optional on other '78-79 trucks. I'm in Portland, OR 97227. |
I am looking to replace my fuse panel box in my 79 F150 4x4. Thanks. Zip 48723
HI,
I'm looking for the intake manifold vacuum fitting for a 360, the one I'm looking for has a large fitting for the power brakes and a couple smaller fittings. Zip is 02857. Thanks! Mike |
parts
I recently bought a 78 f250. it needs door panels, an 8 foot bed, steering column tilt, and other stuff. I'm not sure exactly what all I need because I jusst bought it. This is just a general list. I wonder if it would be better just to talk person to person? I'll give you my email and maybe we can go from there. It is zillsm@yahoo.com thank you.
(Post 11780558)
Ive tried to make some kind of a list. Body/interior/trim: Pair of Rust Free Doors(California Truck) (2)Pair Rust Free Fenders (2) 73-77 Grille Shells(1 mint-painted orange) (3) 78-79 Grille shells 73-75 grille inserts(not perfect,not bad) 76-77 grille inserts(painted black) 78-79 grille inserts(black,argent and chrome) Tailgate trim(all styles and colors I believe) Misc body stainless trim(no 8' bed trim,sorry) Door panels(black,brown,blue,tan,pace truck,xlt and lariat) Dash bezels Dash chrome trim-metal Visors A/C dash,compressors,etc Brown Lariat headliner Mechanical: 78-79 Dana 60 Kingpin,High-pinion Front Axle w/354s 9" rears w/350s NP435 for highboy or 2wd 4x4 C6 for np205 4x4 C6 for np203 Intermediate housings for C6 and NP435/T-18/19 to N205 Driveshafts(too many to list) 351m/400 flexplates and flywheels 360/390 flywheel(resurfaced) 351m/400 belllhousings 360/390 bellhousing 351m/400 rear sump 4x4 oil pan 360/390 rear sump 4x4 oil pan Just about any 351m/400 part Lots of 360/390 parts Steering/suspension/chassis: 4" lift coils (F150,Bronco) Rear springs/hangers steering boxes steering shafts frame crossmembers Dana 60 front U-Bolt perches F350 4x4 overload leafs Factory rear blocks Engine mount frame towers Quad shock brackets F250 Highboy 6" suspension lift Thats a short list...Im tired of typing.If you dont see what you need,just ask. YES..I WILL SHIP PARTS.IF YOU REQUEST A PART,GIVE ME YOUR ZIPCODE AND ILL GIVE YOU A PRICE INCLUDING SHIPPING.FREIGHT QUOTES FOR LARGER PARTS ARE BUYERS RESPONSIBILITY. |
I need a headlightswitch bezel and a wiper switch bezel for a 73-79 f250 and i also need the black trim gauge cover w/o air with all the screw holes not broke out. if you have these let me know please.
Tim |
re-reply
I obviously don't know what I'm doing on this site. I sent you a message and the reply I got from you I guess I don't understand because there is nothing on there but your original post.
