Do you have front bumper brackets for a 1975 F-250 Highboy? shipping to 66002
Originally Posted by 351coupe
(Post 12360766)
Do you need it for 2 or 4wd?
Do you have a 2150 motorcraft carb it must have the choke pull off and linkage on it?The number on my carb tag is (D7TE CUA). My zipcode is 74604 Thanks
06247
hampton,ct need parts |
Grasfarmer-Sorry,I'm looking for a set myself.
Okie-Sorry,no luck. Btracy-Got parts...what do you need |
how about black door panels for 79 f100,
desent shape, dont have to be perfect, and if you dont have black, any color will do, they are just temporary, 40380 ky. |
73 -79 ford cab
Originally Posted by benbuilder
(Post 12358074)
do you still have the dash bezel? 1975 ford f100?
Quietriot29@cox.net |
Originally Posted by trubador
(Post 12367588)
Do you still have rust free doors? 98565
Originally Posted by dmarsh2400
(Post 12376803)
desent shape, dont have to be perfect, and if you dont have black, any color will do, they are just temporary, 40380 ky. Since they are just temporary,are you willing to use aftermarket?If so,I can give you a better deal |
Need fuel door assy. for 77 f100 to 25413.
Thanks Glenn |
Im looking for driver and pass. side door panels. Doesnt matter color as I can paint them. Decent quality is fine and aftermarket isnt an issue. Got anything?
need 79 supercab frame crossmembers
im looking for radius arm brackes for a dana 44 off a 79 and the lower coil spring mounts also i need the 4 " lift springs all for the same year
looking for cruise control set for a 78
Hi, I need a fuel sending unit for 73 f350 SCS "plastic tank " any luck ?
Bill |
grill insert and shell for 78F250 shipped to 75070, possibly a windshield as well
definately interested in the black set, Buy once, buy smart... can you send pic of set. and what is the cost..
if ya dont mind, what are you asking for the after market panels... ( what is the difference in the original and aftermarket ?) appreciate the responce, looking forward to dealing with ya. |
looking for 63-76 f250 locking hubs. shipped to 98366
front axle complete?
Looking for complete front axle low pinion and closed knuckle paul @
pp7331@aol.com |
after market are fine.... what is the price on them,
what would you be asking for the black ones vs the brown set |
need a good 9" rear axle for my 78 F-150 custom super cab shipped to 86046
Looking for a 9in, 3.50:1, 31 spline third member only shipped to 37643. Looking to buy one soon since mine just blew the main caps. Housing is fine and so are the axles, I just need the third member. Would be best to contact me at countmorbius17@yahoo.com, but would be fine through here as well.
grille inserts
I need a pair of 1975 grille inserts?
Still got 'em? Thanks! |
looking for a front drive shaft for a hp dana 44. truck is a 78 f250 with a 4 speed mated to a np205
Do u have any f350 68-74 2wd beams/radius arms and f350 75-79 2wd beams/spindles?
Thanks. 6237928718 robjs111@yahoo.com |
You have any Black Door pieces?
Sorry but I do not.
Thanks. |
Lookin for a pedal set for a 78-79 F250, 4 speed with power brakes. If you have a set, give me a price with shipping to 45601, thanks.
im looking for power steering and disc brakes out of a 2wd truck for my 66 f100
I am in the market for a set of supercab moveable or "vented" rear windows. The entire assembly if possible?
In need of a Dana 44 front axle and dana 80 rear axle, condition is not important, will rebuild. hopefully you can help and TY in advance
Seats?
(Post 11780558)
I have LOTS of 73-79 truck and 78-79 Bronco parts.I've been hoarding parts for too long,and some stuff has to go.A few trucks Ive stripped are:'78 Broncos,79 Supercab,78 F250 4x4,79 F350 4x4,75 F250 4x4(california,rust-free),78 F-150 shortbed 4x4,an Indy Pace Truck and more.If you need parts...chances are decent that I have it.
Ive tried to make some kind of a list. Body/interior/trim: Pair of Rust Free Doors(California Truck) (2)Pair Rust Free Fenders (2) 73-77 Grille Shells(1 mint-painted orange) (3) 78-79 Grille shells 73-75 grille inserts(not perfect,not bad) 76-77 grille inserts(painted black) 78-79 grille inserts(black,argent and chrome) Tailgate trim(all styles and colors I believe) Misc body stainless trim(no 8' bed trim,sorry) Door panels(black,brown,blue,tan,pace truck,xlt and lariat) Dash bezels Dash chrome trim-metal Visors A/C dash,compressors,etc Brown Lariat headliner Mechanical: 78-79 Dana 60 Kingpin,High-pinion Front Axle w/354s 9" rears w/350s NP435 for highboy or 2wd 4x4 C6 for np205 4x4 C6 for np203 Intermediate housings for C6 and NP435/T-18/19 to N205 Driveshafts(too many to list) 351m/400 flexplates and flywheels 360/390 flywheel(resurfaced) 351m/400 belllhousings 360/390 bellhousing 351m/400 rear sump 4x4 oil pan 360/390 rear sump 4x4 oil pan Just about any 351m/400 part Lots of 360/390 parts Steering/suspension/chassis: 4" lift coils (F150,Bronco) Rear springs/hangers steering boxes steering shafts frame crossmembers Dana 60 front U-Bolt perches F350 4x4 overload leafs Factory rear blocks Engine mount frame towers Quad shock brackets F250 Highboy 6" suspension lift Thats a short list...Im tired of typing.If you dont see what you need,just ask. YES..I WILL SHIP PARTS.IF YOU REQUEST A PART,GIVE ME YOUR ZIPCODE AND ILL GIVE YOU A PRICE INCLUDING SHIPPING.FREIGHT QUOTES FOR LARGER PARTS ARE BUYERS RESPONSIBILITY. I'm looking for a 40/20/40 seat |
How about a crossmember the one behind the cab under the front of the bed? thanks
I'm the molding that runs along the side of the truck. Mine is a short bed regular cab
iterested in if u have any beds call me 732 267 5736
I am looking for 76 360 smog parts?
Need a highboy steering box. Pmed you. Thanks.
How about a Dana 60 front axle for that would fit a (pre 77.5) 77 HiBoy F250. 3" wide leafs with 31.5" leaf centers. You know if that high pinion will fit? Ship to 29909.
separate quote for 78-79 F250 4x4 power steering box and intermediate shaft. Same Zip. Thanks. M |
Originally Posted by TaskMaster
(Post 12676069)
I need a fuel vapor valve that goes in the gas tank for a 1978 F100. Would you possibly have one of those for sale or maybe tell me where I could find one? Zipcode 28356
