Still have a flat head if so how much?
Originally Posted by mlandrum51F1
(Post 12191012)
I would definitely be interested in the heater (need controls too) and the complete seat, brackets and all. Please let me know costs and I'm sure we can work something out. Do you have pictures online by chance?
Okay what heater are you interested in? I have a seat, but it has issues. ( I think the track is messed up) I can get pictures for you. Im sorry for the delayed response. |
Originally Posted by 1952Fordf1
(Post 12333865)
Originally Posted by noballjohn
(Post 12191315)
Looking for 2 good doors for a !950 F-1. Any available?
By the way, If I do not respond on FTE, email me at "jkeeslin@purdue.edu" I check this email several times a day. |
Do you still have the 2 speed rear off the f-6 and is it same width as the 50 f-5 bus
I do still have the rear axle and yes it should be the same. They used the same wheels and frame width so it would have to be the same.
Very cool I honestly am not familiar i was told that i would basically have better highway rpm. Do you know if this swap could help or hinder?
Well It depends on what size tires you are running and what the ratio is of the axle you already have. I have a 54 f600 with 8.11s on the low and 5.88s ( i think) on the high. with nothing on the frame it will run about 65 mph, but that is wound up about as high as it can go
Well I'm in the process of getting a set of 19.5 and I think there 225 70
I am not sure how tall those are, but you might want to do some calculations or get an overdrive transmission.... I do know that having a low side is really nice on that f600, lots of power and going to high in 3rd is nice too.
Hello well i am working out my rim issue i found a couple so far but there 22.5 and how much do you want for that? The low gear i plan on using putting thru pits
I have all the plumbing for the vacuum also. It is also still attached to the frame with the springs. (I cut the frame off to save the springs in case someone needed them)
I think 250.00 for all of it is fair? what do you think? |
Well that's perfect I am north of you in grand rapids I will keep in touch to figure out when I can come down
Okay, let me know. I have machines to load it with, I can take the springs off and put it in a pickup bed or whatever you want to do
Im thinking whole prob will work out better I have a trailer that it will fit also thank you for the knowledge its helped out tremendously.
