Dieselsite coolant filter warning/fix (with pics)
Hey guys, I recently had a problem with my Dieselsite coolant filter. I had a little problem that caused me to loose a lot of coolant and make a huge mess of things. The heater hose T-fitting is obviously spun on a lathe as well as the barb but the problem is that the 3/8 barb fitting is simply press-fit into the main tube. Which when under pressure caused the barbed portion to pop out and dump super-heated coolant all over everything. I fixed it by simply drilling (8.5mm) and taping (1/8NPT 3/8) hose barb in it's place and it's now it's good to go, for good. Anyway, I figured you guys would like to know of a potential source of a sudden coolant drain. Here's the pics.
Before: http://i52.tinypic.com/23ib12u.jpg After: http://i53.tinypic.com/2vuemwy.jpg |
have you notified dieselsite about this problem?
Thanks good to know....I'll keep an eye on mine..Nice job
I used a cheap black molded one for my DIY kit
http://s7d5.scene7.com/is/image/Hard...id=200&hei=200 |
Originally Posted by havns3
(Post 9617208)
Originally Posted by High Binder
(Post 9617335)
Not yet I was going to call him today but got stuck hanging X-mas lights, will do tomorrow though.
(Post 9617335)
I bought mine 2 months ago, I will check mine tomorrow AM in daylight! Thanks for the heads up! |
Originally Posted by Zmann
(Post 9617278)
Originally Posted by Misky6.0
(Post 9617350)
How long ago did you buy your coolant kit?
Same thing happened to me with the same kit about 8 months ago. I couldn't believe how cheap of a T it was. I went to car quest and a new plastic T.
I wonder if they will follow through with fixing "THEIR PRODUCT".
Thanks for the post. I will keep an eye on mine :) |
I made my own, so I was in charge of quality control. I used copper fittings.:-dancing1
wow what a pile of junk. glad i didnt get one.
mine is leaking a little bit.
High Binder. You should let diesel site know of this post. |
I used a 1"X1/2 pex plumbing tee, you can get this at any plumbing supply store. the other tee is just a straight 1/2 pex tee. they are made of brass, they will last for ever. I would never use anything else. vangard is one maker of the pex tee. don't go to home depot type plumbing stores, they have them, but may not know what you are looking for. good luck, my is working fine.
