Crown Vic swap to F100 questions
Old 02-16-2009, 10:19 PM
bman1080's Avatar
bman1080
bman1080 is offline
I have a 1953 F100 and a 1986 Crown Vic. I would like to know what all I will need and is compatible to swap into the 53? I am considering keeping it fuel injected. Also will any of the brakes work on the 53?
Thanks
Billy
Old 02-17-2009, 01:18 AM
Julies Cool F1's Avatar
Julies Cool F1
Julies Cool F1 is offline
Well, in general:
The brakes will work in the 53 if you make them work.
As far as dropping the CV engine in the 53 for a start, you'll need to convert it to 12 Volt negative ground. You'll need new motor and transmission mounts - drive shaft of course. And the usual hook up mods - shift, throttle, ignition, probably modify the exhaust, radiator connections, transmission cooler.
There's probably tons more but that's a good enough start. You and 55F350 will probably get along famously.
Old 02-17-2009, 08:00 AM
thepitshop's Avatar
thepitshop
thepitshop is offline
this is what i grabbed, the complete front end, gutted the car and grabbed the complete harness, grab the master and booster, rear end, steering column, front seat if you want, i`m not using them because i feel there a bit too big for the cab, fuel lines, i haven`t got to the radiator part on my truck but by just laying it in place looks like it also can be used, and i think thats about it! i`m using a mustang fuel tank and will probably try and modify the crown vic fuel pump to fit in it, wiper motor will also be modified and fit to the f100 wiper system, and i think thats about it!
Old 02-17-2009, 08:49 AM
tacson's Avatar
tacson
tacson is offline
Where are you located Bman?
Old 02-19-2009, 12:25 AM
bman1080's Avatar
bman1080
bman1080 is offline
Thanks I appreciate all the info. I am in Austin, Texas.
Old 02-19-2009, 06:52 AM
tacson's Avatar
tacson
tacson is offline
PM or look thru my gallery. I will help you all I can.
70f100bb
33
03-02-2020 09:23 AM
red05interceptor
136
12-23-2019 12:21 PM
Carmax
13
10-17-2018 12:02 AM
DasHaas
13
08-31-2014 05:00 PM
1967leroy
General Automotive Discussion
04-03-2014 07:49 PM
Quick Reply: Crown Vic swap to F100 questions
